LED conversion for my 14 FLHP
Old Jul 11, 2018 | 06:11 PM
james rist's Avatar
james rist
Stage II
Default LED conversion for my 14 FLHP
pls help. I swapped my factory headlight for a LED light. It’s installed - but the high beam won’t work. I’ve swapped the high beam/low beam plugs several times but no luck ... is there an easy fix to this?
Old Jul 11, 2018 | 08:10 PM
SWMB's Avatar
SWMB
Not sure if this will be your problem but I know LED lights are ground specific. So you could try changing your ground and power wires. Not sure if this will fix your problem but it might be worth a shot.
Old Jul 11, 2018 | 08:14 PM
james rist's Avatar
james rist
Stage II
Default i’ll Try
Thank you.
Old Jul 12, 2018 | 04:06 AM
Lin Edc's Avatar
Lin Edc
1st Gear
Si longtemps pour vous, je pense que tu peux changer un phare dans novsight essayer, bon, il a travaillé pour moi pendant un an, est très brillant.
Sierra977
Aug 23, 2018 09:41 AM
zachr4x4
Nov 4, 2015 12:38 PM
Racinboy
Electrical/Lighting/Alarm
Jul 6, 2014 11:56 AM
OwnerOfHarriet
Feb 19, 2014 04:26 PM
DeafDude
Mar 26, 2012 08:36 PM
