Voltage Regulator
Old Jul 24, 2018 | 08:05 PM
demorgan's Avatar
demorgan
Stage II
Default Voltage Regulator
What is killing my voltage regulator?
Old Jul 24, 2018 | 08:29 PM
RG Pilot's Avatar
RG Pilot
Poisonous volts?
Old Jul 24, 2018 | 08:49 PM
sanman4ever's Avatar
sanman4ever
oh boy.........
Old Jul 24, 2018 | 09:07 PM
Veekness's Avatar
Veekness
De bad juju...
Old Jul 24, 2018 | 10:15 PM
hattitude's Avatar
hattitude
The battery, stator, and voltage regulator all work together...... If one goes bad, it can damage one, or both, of the other two...
If you've been through a couple voltage regulators in a short period of time... check both the battery and the stator before you replace another voltage regulator...
For example, let's say you have a bad stator, it's not producing the voltage it should and it takes out the voltage regulator. If you replace just the voltage regulator, without also checking the battery & stator, the bad stator will ruin the new voltage regulator in short order...
Obviously load test the battery, and search this forum.. there is a procedure for checking the stator with a voltmeter....
Good luck...
Old Jul 25, 2018 | 03:29 AM
nytryder's Avatar
nytryder
The neighbors Pit Bull??
Old Jul 25, 2018 | 03:54 AM
Kingglide549's Avatar
Kingglide549
Not flashing the field!
Old Jul 25, 2018 | 05:12 AM
grbrown's Avatar
grbrown
Red face
It really helps us to help you if you give us more to work on! What year and model is your bike? Have you had only one regulator fail, or more?
Old Jul 25, 2018 | 05:16 AM
duglaura&flhti's Avatar
duglaura&flhti
First post....Welcome to the HDF.
Old Jul 25, 2018 | 02:52 PM
demorgan's Avatar
demorgan
Stage II
2005 FLHTCUI 14000Mi lost the stator first then 2 regulators ck the batt 540 cca I'm at a total loss,and the alternator has 70 volts AC at about 4000 RPM.
