Intermintant no-start
I have a 14 Limited and like you just love the bike.like mmesa said check for DTC's https://dgcustomcycle.com/tech/harle...es-04-present/
run1fsr has a good question, did anyone change handle bars?
The Security light stays on if you have a current DTC. The ABS light stays on if the ECU detects a problem, which may disable the ABS or when the speedometer detects a loss of communication with the ECU.
If your bike wasn't sensing your Fob the headlight won't come on when you turn the ignition to on. The Odometer display will ask you to enter your PIN, (check your owners manual if you haven't done this yet), and the light comes on when the PIN is accepted.
Our bikes have a CAN, Controller Area Network, communication system. The bikes Modules transfer data through the CAN system. When you press the horn button it sends a signal to the BCM and the BCM powers the Horn.
Once you pull the codes, write them down, then post them and maybe it's something you can check
Bill
