Handlebar Switch Swap
If it is a CanBus bike ('14+), this is an easy change, just two switch-paks , each with small plug-in connectors. Plug & play with OEM harness.... If it's a pre-Canbus bike, it will involve individual wires, individual switches, pin swapping, connector changing, etc..
If it's a Canbus bike, there are different numbers for the left side and right side switch-paks. There will be two switch-pak numbers for the right side. One will have a push-to-talk (PTT) button, and one will not. Each side switch-pak will cost $181 from an online HD vendor.
You can also opt for a lighted switch-pak set. That has one part number, comes with a PTT switch, lighted buttons, and costs $206 for both switch-paks from an online vendor...
My '16 Ultra Classic did not come with a CB, and did not have a PTT button. My left switch-pak had one of the buttons fail. When I saw how much each individual switch-pak cost, and that I could get a lighted set, w/PTT button, for slightly more than one OEM switch-pak, it was a no brainer for me. The PTT button worked with my intercom and phone bluetooth, without any need of a flash from the dealer...
Example: My '16 Ultra Classic: left side switch-pak #71500128B for $181.00. The right side switch-pak is #71500129C for $181.00, w/o the PTT button. The lighted switch-pak set, that comes with both switch-paks, lighted buttons, and a PTT button is #71500248C for $206.00. (all prices from HD BoardTracker Online).
HTH,
Hoggly
