Noise
Old Sep 23, 2018 | 12:08 PM
rculbertson102's Avatar
rculbertson102
6th Gear
Default Noise
At cruising speeds I have a high pitch metallic noise on the left side???
any ideas???
Old Sep 26, 2018 | 10:47 AM
jakewalter's Avatar
jakewalter
Might sound silly but I took my bike into the dealer yesterday for the same reason.
I have about 8700 miles on the tires.
the tech, after he took it for a ride showed me that the tires were cupping on the left side causing the problem.
Old Sep 26, 2018 | 08:38 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Possibly could be the Primary Chain doing what it's supposed to do which is to go around in a loop really really fast!
Old Sep 27, 2018 | 06:33 AM
RoadHog659's Avatar
RoadHog659
Gas cap door button buzzing?
Shifter linkage loose?
Footboard rattle?
Exhaust heat shield rattle?
Old Sep 27, 2018 | 07:26 AM
Tarkus60's Avatar
Tarkus60
It is amazing how loud a loose Shifter linkage can get!
Old Sep 27, 2018 | 07:40 AM
oldhippie's Avatar
oldhippie
Another high pitch noise can be a final drive belt not properly aligned to the final drive sprocket. This will happen more as the bike gets up to temp.
Old Sep 27, 2018 | 06:42 PM
Mr. Mike's Avatar
Mr. Mike
I don’t see where you listed your model, but in the event it’s a touring, I’ll throw this at it;
Broken rear exhaust support bracket right above the starter motor, towards the left side.
Spider0408
Aug 29, 2018 04:39 PM
Byron Loyd
Sep 5, 2016 08:04 AM
Barthel75
Jul 10, 2016 07:32 PM
JWP79
Sep 27, 2010 11:27 AM
BLACKTOP GLIDER
Northeast
Apr 23, 2010 08:41 AM
