Any major problems
When you hit around the 50,000 mile , you may have compensator cluck, (this is not uncommon with the older compensator)….. Also the starter clutch may start to fail because of compensator clunk...
These are not huge problems,, just par of the course for these year bikes... Hell, even the newer bike can have the same problems.... All other problems people have, like say,, tensioners ,, brake rotors warping ,, etc,, are just mileage things, and happen to all bikes....
I had 85,000 miles on mine when I sold it, and other than the above problems.. Other than normal maintenance , the bike was trouble free.... I was sad to see her go !!!
If you buy the 2009 FLHT with 10,000 miles at the right price, you will have a great bike, that is a blank canvas to make it the way you want it.....
If I can find a pic of my old girl I will post it up for you ….. cheers …..
For the most part it's been fairly trouble free so far... but a couple things I have had trouble with...
- A broken wire in the throttle body wire harness. This seems to be a fairly common issue... maybe not all bikes, but many. It took me a bit to find, but basically one of the wires in the harness had broken inside the wire's jacket. After soldering in a length of wire, it's running fine again.
- I've recently noticed oil under the bike. I'm not certain yet, but it seems to be coming from where the crank case comes together on the bottom side of the engine. I've tried tightening the two bottom bolts a bit (I don't know the torque needed, so, I've not over tighten), but it still leaks a little (not much, just a quarter+ sized spot in the garage over night).
- I adjusted the clutch (it was slipping a bit)... this is really just regular maintenance though.
Ride Safely!
John.
