12” Apes
Old Oct 9, 2018 | 05:37 AM
I8AGSXR's Avatar
I8AGSXR
Default 12” Apes
do I need extensions to install 12” apes on my 2016 street glide?
Old Oct 9, 2018 | 01:57 PM
Jshopes's Avatar
Jshopes
Probably depends on style. Supposedly you can do 14s without extensions. Factory 47 has a great video on youtube. I did 10" yaffes and was fine aside from wiring the pieces of ****.
Old Oct 9, 2018 | 03:08 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Kind of depends on which bars. They are all measured differently.
I put WO578’s ((10 inch) on 2016 Limited no problem. Only needed the Namz wire extensions and NO clutch or brake.
I put Yaffe 10 inch Monkey Bars on my 2017 CVO Limited. Same as above.
The wire extensions are a must but they are very little money.
As as for the clutch and brake hydraulic lines that is a different story. Mine were stretched tight with the 10 inch bars. You can rework/ reroute them and get them to fit with a little work. I would personally switch them out.
As mentioned there are a lot of threads on this and a lot of videos. A quick Google search will give you some great videos showing how to make it work.
Good luck
Old Oct 9, 2018 | 03:22 PM
Stroked16's Avatar
Stroked16
You don't "need" wire extensions. Follow the Factory 47 video and they will show you exactly what you need to do. I have 12" Spooky bars with plenty of wiring to go to 14s.
If you want to get an extension for the wiring, just for peace of mind, it's like $40 at a dealer. Good luck.
steelerdude1
2014-2024 Touring Models
Nov 11, 2015 06:37 PM
Curtis_707
Jun 22, 2015 12:16 PM
Robtarra39
Jan 2, 2012 06:47 AM
DAVEY
Jan 21, 2007 08:22 PM
