Ignition Issue
Old Oct 20, 2018 | 10:02 PM
Wmbailey5's Avatar
Wmbailey5
Default Ignition Issue
occassionally my starter button on RH handlebar sdoes not work. Requires me to turn ignition and off a number of times b4 it will start.
I did have my bike flashed for a RF amp.
Anyone else having this issue?
Old Oct 21, 2018 | 08:04 AM
ORradtech's Avatar
ORradtech
Probably need a new ignition switch.
Old Oct 21, 2018 | 08:22 AM
Screamin beagle's Avatar
Screamin beagle
Yup ,happens to mine if it sits for a week or so...not often during riding season. I usually have to turn it to a cerain spot for it to work. Its on the list of winter maintenance items to be replaced.
Old Oct 21, 2018 | 11:14 AM
Wmbailey5's Avatar
Wmbailey5
Thanks for responding.
The bike does sit for a week sometimes and I will see if there is a relationship to this.
I also lost the heated grips on my bike after the flash so that is why I went in the direction. Could be a coincidence.
Old Oct 21, 2018 | 11:50 AM
FPV's Avatar
FPV
Long ago was stranded due to funk'd starter switch now all my rides have one of these. Can be found for around half JP's price if you look around. Just be sure you're in neutral before the button is pushed. Found that out the hard way.
Old Oct 22, 2018 | 07:06 AM
grbrown's Avatar
grbrown
Lightbulb
That's not a solution!
Old Oct 22, 2018 | 07:30 AM
FPV's Avatar
FPV
Clearly not to you!
Old Oct 22, 2018 | 07:36 AM
grbrown's Avatar
grbrown
Cool
Clearly not to you!
Your bike seems to have an electrical problem, so solve it, or find a man who can.
Old Oct 22, 2018 | 07:41 AM
FPV's Avatar
FPV
Wow!! I do not believe I used the word "solution". However, what I posted is definitely a damn good workaround should a starter button/switch fail while out on the road. Opinions are like asses and elbows.....everyone has them.
Old Oct 22, 2018 | 07:42 AM
grbrown's Avatar
grbrown
Thanks for your wisdom.
