Need help with error / check code
Old Jul 1, 2007 | 10:30 PM
hadacall's Avatar
hadacall
Default Need help with error / check code
I tried to post this a half hour ago, did not see it post so I'll try again.
2006 Electra Glide Classic, engine check lamp stays on. I ran the Engine check Codes and this is what I get; NO rSP and PN 68922-00dI did replace the Plugs earlier today, gap set at .40 in. Can someone advise?
thanks,
Old Jul 1, 2007 | 11:17 PM
gman's Avatar
gman
Default RE: Need help with error / check code
you might want to clear your codes, and retry. the part # you listed is the security system module. not sure what NO Rsp means, but maybe No Response? did you do anthing to the security system?
DPete
Mar 15, 2013 03:48 PM
happyfeet
Mar 23, 2010 08:33 PM
watercop
Jun 22, 2009 06:37 PM
earlehd
Apr 6, 2008 07:33 PM
hadacall
Jul 1, 2007 10:55 PM
