Handlebar controls question
Old Oct 29, 2018 | 09:19 AM
BrysZ's Avatar
BrysZ
Default Handlebar controls question
Hello,
I have installed a OEM cb on my 2012 streetglide and purchased the necessary harness and everything to make it plug and play and everything is working fine except I do not have the PTT/Squelch button on the left hand control. I purchased a real nice left hand control off a 2009-2013 ultra thinking I could merely plug and play but NO. The street glide left hand control to main harness plug is entirely different then the ultra plug. In fact one is male and the other female so am I at a dead end? I seriously thought all main harnesses for touring were the same and some plugs and/or wires are used or not used depending on the bike. IDK what to do now...any suggestions? Thank you.
Old Oct 29, 2018 | 02:29 PM
cncmike's Avatar
cncmike
Are you absolutely sure you have the correct connection? There are intermediate harnesses involved. I think you are correct that all 2009-2013 hand controls for touring bikes should interchange. They would just have more or less wires from the connectors.
Old Oct 29, 2018 | 10:05 PM
BrysZ's Avatar
BrysZ
The seller told me they are the left hand switches for a 98-13 touring. Definitely the wrong connector for my main harness. The ultra switches I bought have a connector with only 12 pins...no empty positions. My street glide connector has 12 pins but with 4 empty positions for possibly 16 pins. The below pics... pics 1 thru 3 are the street glide left handlebar control 16 pin connector. pics 4 thru 6 are of the ultra left handlebar control 12 pin connector.
ultra connector wiring...
1- orange, 2- yellow, 3- blue, 4- white , 5- white/violet stripe, 6- yellow/black stripe, 7- violet/black stripe, 8- brown/black stripe, 9- pink/white stripe, 10- green/black stripe, 11- gray/green stripe, 12- orange/black stripe
street glide connector wiring...
1- orange, 2- yellow, 3- blue, 4- white , 5- white/violet stripe, 6- yellow/black stripe, 7- black/ red stripe, 8- brown/black stripe, 9- pink/white stripe, 10- green/black stripe, 11- gray/green stripe, 12- black, 13 thru 16 empty.
thank you for any help... hopefully I can swap connectors and use these ultra switches on my street glide.
Thank you
Old Oct 30, 2018 | 06:41 AM
BrysZ's Avatar
BrysZ
maybe easier to follow
Old Oct 30, 2018 | 06:45 AM
BrysZ's Avatar
BrysZ
pic
connectors
Old Oct 30, 2018 | 06:49 AM
BrysZ's Avatar
BrysZ
schematic
Old Oct 30, 2018 | 07:51 AM
BrysZ's Avatar
BrysZ
ok it appears the ultra controls are only 2008 and earlier not 98-13 as advertised ugh! could someone PLEASE tell me if I could simply swap connectors and how? I have to extend wires anyway for apes. Thank you so much for any help.
Old Oct 30, 2018 | 09:41 AM
BrysZ's Avatar
BrysZ
It appears pre-2009 had no clutch lockout switch possibly?
Old Oct 30, 2018 | 06:30 PM
BrysZ's Avatar
BrysZ
drill a hole and swap out clutch button and connector
Old Oct 30, 2018 | 07:19 PM
14GuineaPig's Avatar
14GuineaPig
If you're looking for wiring diagrams, go to the HD Service Info Portal and type the year & wiring in the search box …. "2008 wiring"
https://serviceinfo.harley-davidson....67c6008f3!!1!6
The 2008 Touring had a clutch lockout. The R/S control is 12 pin and the L/S is 16 pin.
IIRC the clutch lockout started in 2007
