Issues with Neutral
Old Oct 29, 2018 | 03:40 PM
Stoneez's Avatar
Stoneez
2nd Gear
Default Issues with Neutral
There is a real possibility that this is a FNG question, but I am a FNG especially when it comes to HD's. I recently purchased a 1998 Ultra Classic, and it is a real challenge to get into neutral. Is this a normal issue for this year and model, something that mine is just temperamental about, or is this indicative of a larger issue? This is not a MAJOR issue, but an annoyance just the same. Any ideas would be greatly appreciated.
Old Oct 29, 2018 | 03:49 PM
RDHIGH's Avatar
RDHIGH
This issue comes up quite often. It sounds like you need a clutch adjustment. One adjustment at the clutch basket(under the derby cover)- and then a cable adjustment at the handlebars. Do you have a service manual? If you plan on doing your own work- get one or borrow one.
Old Oct 29, 2018 | 03:55 PM
Stoneez's Avatar
Stoneez
2nd Gear
Thank you. I will lay my hands on a manual and look into this.
Old Oct 29, 2018 | 04:03 PM
RDHIGH's Avatar
RDHIGH
No prob bro- enjoy the new ride! If you like spinning wrenches- harleys are fun and easy to work on (most of the time- lol).
Old Oct 29, 2018 | 04:08 PM
Bend Iron's Avatar
Bend Iron
Just my 2 cents. I felt that my 13 SG had a similar problem(coming off of BMW`s). It was frustrating as hell! Once I learned how to barely "snick" the heel shifter, it fell right in. Harder to do with the toe shift for me. Now perhaps you DO need an adjustment, but the adjustment I needed was practice. It really is a feel thing to a certain extent.
Old Oct 29, 2018 | 04:27 PM
tidbit1's Avatar
tidbit1
I have a Street Glide and a Softail Deluxe, they both are hard to find neutral. I just take it as being a Harley.
Old Oct 29, 2018 | 04:28 PM
FreedomRider's Avatar
FreedomRider
once you know your clutch is adjusted correctly … with the bike in first, put a little up pressure on the toe shifter and blip the throttle, it should pop into neutral … this has worked for me with all my bikes …
Bass Player's Avatar
Bass Player
Clutch adjustment, yes. Too much or never changed (dirty) primary oil will do that as well. You will get differing opinions on how full the primary should be. Also what to use in the primary. ( That's almost an oil thread) Bottom of the derby cover hole, bottom of the clutch basket, or just run a quart. See what the manual says. I run to just above the bottom of the clutch basket in both my Harleys. Never an issue.
Old Oct 29, 2018 | 05:13 PM
Kenrbass's Avatar
Kenrbass
adjustments. Good oil. (primary and trans) I also have an extended front shifter because of big feet, but the extra length helps with more leverage to ease it into neutral. Also if you find it while rolling to a stop, it's a lot easier than after you stop.
Old Oct 29, 2018 | 05:39 PM
chuckw2's Avatar
chuckw2
I never tried this in my 94 Dyna WG 5 speed but on my 16 RK 6 speed when we changed to synthetic in the trans it made a huge difference in finding neutral, and in the shifting in general.
