Yes, all 09-later TOURING have an Integral (to the hub) Cush Drive
If you want an OE Cast "Mag" in a wide 16" (without cush drive), about the only one is the 08-17 Dyna Fat Bob 16x5 (athough some of the new 2018-later Softails are using that size)
If you want to move up to 17" ... you may be able to work with 2006-later 17x6 wide hub Softail wheels (some models)
Of course there is the 17x4.5 from different Dyna, Softail, and Sportster Models
Not really concerned with the OE style of wheel, can't really see it anyways.
Good to hear there are some other options. I'm still feeling like I'll be sticking with the 16" wheel, unless I can find a good deal on one.
I wasn't really talking about what they looked like ... I was just telling you that the Factory 09-later Touring wheels have a Cush Drive that is NOT removable...so you have to have to work with it
And if you decided to go the "NO Cush Drive" Route you could look at those other Factory "Wide" wheels (including 16") as an option (and relatively cheap)
Of course you can use aftermarket wheels with more options
Good Luck
I put a Softail 17x6 Solid wheel and 200 tire on my 09. Used a sportster pulley along with custom axle and rotor spacers. Been working fine but no real advantage other than looks...
Good Luck
My apologies multihdrdr, didn't mean it to come off that way. Looking more for function than for looks. I appreciate any and all of your input.
Oldhippie, I found a Fatbob wide rear rim that is 16 x5. However, a lot of the tires I'm finding all say to mount on a 5.5" rim. Other than a narrower cross section, what are the issues of mounting a 5.5" suggested rim tire on a 5" rim?
Found another rim, 17x6, could be from a deuce, Does anyone know if the wheel bearings from a deuce wheel can be changed from 3/4" to 1" bearings?
Thanks.
Using a non recommended size firm is never recommended. It not only creates a problem with bead sealing but also messes up the contact patch (ask the low rider folks about tire problems). Yes the bearings can be changed. I used a 17x6 from a Softail on my 09. Cant remember if the bearings needed changing??
As recommeneded earlier, check with manufacturer's websites. I've already shown that there are alternative widths of tyre that will fit your 6" wide rim.
Thanks.
I have an early Deuce rear wheel in my Glide, which has a 4.5" wide rim and takes a 160x17 or 170x17 tyre. Yes I converted it from 3/4" to 1" bearings, they are a direct swap in the wheel, although require a different length central spacer, between the bearings. There are several styles of Harley wheels with the same rim size available. A later wider Deuce wheel is more likely to take metric 25mm bearings IMHO and I suspect will require a wider swingarm.
Just ordered a 2009-2013 swing arm with axle. Will be doing some dissecting this swing arm issue next weekend. I would like to stay with the 16" rear wheel if at all possible. We'll see what comes up in my reading. Thanks for your input. It is appreciated.
Have you gotten dimensions for the 2007 swing arm width ( at the pivot point ) and the 2009 swing arm? ... I looked for a bit and was unsuccessful .... I got into a similar situation with my 1979 FXEF when converting to a later model belt drive ... A little bit of research and a bit of "finalgaling" got me to where I wanted to be ... Good Luck
Not yet. That info seems kinda hard to find. I will be doing some measuring when the 09 swing arm gets here and will hopefully get it figured out.
Other than the generic "09 and later frames have been improved" statement, I haven't came up with any particular measurements that be compared to an '08 and earlier frame. I'm know that the fender support has changed because of the wider rear fender for the 09's and newer, but not much more than that when it comes to adding a wider rear tire.
While quite a few members have used twincam swingarms in earlier bikes, because they are almost a straight swap, I've only seen a couple of members who have tackled this, one of them with a shovelhead, believe it or not!
