Compensator and clutc
Old Nov 14, 2018 | 07:06 PM
freedom4me's Avatar
freedom4me
Default Compensator and clutc
I have a 2010 Electra Glide it's got 40k miles on it and everything in the primary is stock. I'm looking for suggestions for the compensator, dont really want to go with Harley! Also im looking at replacing the clutch, the current stock clutch slips no matter how I adjust it. My trips are long and pull a trailer with camping gear, i do have a stage 2.
Last thing I'm in Canada...
TIA
Old Nov 14, 2018 | 08:33 PM
Notgrownup's Avatar
Notgrownup
Baker compensator, Barnett Kevlar extra plate clutch and heavier spring
Old Nov 14, 2018 | 08:37 PM
TwiZted Biker's Avatar
TwiZted Biker
Baker comp and not much you can do with the way you load it, any clutch is going to cook sooner or later.
Old Nov 14, 2018 | 08:46 PM
RDHIGH's Avatar
RDHIGH
All good choices notgrownup! Try Fortnine.ca for the barnett extra plate kit - and the heavy spring. That is- if you think you need the heavy spring with the new clutch. Id try it without the spring first.
They dont sell the compensators there though- believe me- i keep checking. Your best bet may be to buy directly from baker. I think they have a sale or special on soon. Im not sure....
Old Nov 14, 2018 | 08:52 PM
TwiZted Biker
Baker is a vendor here in the Forums and Mark@ Baker Drivetrain is a regular member, good people be worth a phone call or a PM to him.
Old Nov 14, 2018 | 09:21 PM
Notgrownup's Avatar
Notgrownup
Maybe all you need is a heavy spring.
Old Nov 14, 2018 | 09:31 PM
HD Bobber's Avatar
HD Bobber
At 40k personally I would do the Baker comp and Attitude Adjuster along with new clutch setup of your choice, since you’re going in there to make changes.
Old Nov 14, 2018 | 09:34 PM
TriGeezer's Avatar
TriGeezer
I have about 20,000 miles on a Baker Compensator, SE Clutch with SE spring, and running HD formula +. With the heavy TriGlide, 2 up, loaded with luggage. No more Compensator clatter or clutch chatter....
Old Nov 14, 2018 | 09:45 PM
freedom4me's Avatar
freedom4me
Fortnine definately doesn't have the compensators. I also will be getting the heavy duty spring with the clutc also.
I take your also Canadian?
Old Nov 14, 2018 | 09:49 PM
freedom4me's Avatar
freedom4me
Good to hear Baker is part of the forum. I did talk with someone there and also asked about a clutch and apperantly the will have one out this spring.
Hopefully he'll chime in.
