Advanblack King Tour Pack Pak Lighting
Old Nov 19, 2018 | 07:31 AM
aviscomi's Avatar
aviscomi
Default Advanblack King Tour Pack Pak Lighting
I have a question for those of you that have the Advanblack King Tour Pack Pak. Have any of you installed lights on the Tour Pak? Such as the LED King Tour-Pak Brake/Turn/Tail Lamp Kit. If so, how was the fit and what else is needed?
Thanks in advance!
Oh, my bike is a 2018 RGS
Old Nov 19, 2018 | 11:33 AM
Hammerhead Pat's Avatar
Hammerhead Pat
I have the their king pack on my 2011 FLHR. I have the run/turn/brake setup on my bike and I just tapped into the wiring heading to my rear lights. The lights ( on the side of the box) came with the pack and I think they fit just fine....
Old Sep 26, 2019 | 09:52 AM
Ssitruc's Avatar
Ssitruc
wrong thread
Old Sep 26, 2019 | 04:23 PM
FastDude2020's Avatar
FastDude2020
King tourpack with LED side lights looks good.
Old Oct 2, 2019 | 07:05 PM
UHDhog's Avatar
UHDhog
I installed the "cheap" ($100 flebay) smoke LED tail light on my Advanblack King Tour Pak. Light was a perfect fit. I also installed a set of smoked LED side marker lights that fit perfect as well (these plug right in with the factory H-D TP wire harness). You will need a NAMZ pigtail and a factory H-D tourpack wire harness. It is all plug-N-play.
You will need some skills on measuring / taping to install the light. A hole needs to be cut in the back/left corner to accomodate the tail-light connector as well as the holes for the mounting screws.
hacksaw57
Mar 22, 2018 10:07 AM
junior166745151
Feb 27, 2016 10:26 AM
FL-kruzen
Oct 5, 2013 01:44 PM
rando1954
Aug 11, 2009 07:31 PM
Meist21
May 9, 2009 06:37 PM
