I have an '06 Electraglide with an S&S 100 ci
kit installed- had headwork done- 590 lift cams-S&S headers with V&H 4.5 HO slip-ons. Just bought a Performance Machine fast air forward K&N to up grade from the stock air cleaner. Also picked up a HPI 51 mm throttle body. would like to change out the stock injectors.. any recommendations on what brand and size?
I'd throw a set of hpi (horsepower incorporated) injectors in. Call or email and they respond quickly with an answer to your question. They have a great website too.
Do check to make sure if you had the problematic 8* injectors from 2006 that they were changed to the updated 25* injectors though.
^^^check this first. There was a Service Bulletin on the 8 degree injectors for '06 bikes. The 25* injectors are not that expensive if you shop. My '06 has the old injectors and getting ready to change them
2006 FLH bikes have the small 3.91gm injectors which will support up to about 95-100Hp. I would recommend the Screamin Eagle 4.9gm injectors which are our go-to for this application.
