Repair or Buy new bike?
Old Nov 28, 2018 | 08:35 PM
internet troll's Avatar
internet troll
Talk to your dealer again and get specifics. 4 grand for brakes, rotors and a belt/pully combo is absurd. Honestly, belts and pulleys only need to be replaced if they are actually DAMAGED. There is NO WAY you have enough wear on those parts (at 45K miles) to warrant replacement unless something was adjusted WAY out of spec. I used to work for a dealer so I generally understand their point of view, but this seems odd.
Old Nov 28, 2018 | 08:42 PM
Ben221's Avatar
Ben221
You should post the dealer name to warn others away.
Old Nov 28, 2018 | 08:50 PM
DTTJGlide's Avatar
DTTJGlide
It's that time of year, they're trying to keep their shop busy & saw you coming, find an honest shop & get a second opinion. Just take it in & tell them to do a quick check to see if it needs a little winter maintenance, don't tell them what the other shop wanted to do. Unless they find the exact same things I would run fast & never ever go back to the first shop!
Old Nov 28, 2018 | 08:53 PM
tfi racing's Avatar
tfi racing
Valve piston levers? The dealer is right,your bike is worthless scrap when that happens...
Old Nov 28, 2018 | 09:09 PM
Fullbore55's Avatar
Fullbore55
DO NOT test ride an M8!
Old Nov 28, 2018 | 09:11 PM
stewy1200c's Avatar
stewy1200c
Look for a good local Indy. Ask around , do a search. You'll actually get to talk with the guy working on your bike, not just a service writer.
Old Nov 28, 2018 | 09:17 PM
run1fsr's Avatar
run1fsr
Sounds like someone is trying to sell you a new bike.
Old Nov 28, 2018 | 11:25 PM
MatteGlide15's Avatar
MatteGlide15
If you set 1 foot in that Stealership again after that ABSURD price quote you might as well stock up on this and bend over!!!!!
Old Nov 28, 2018 | 11:32 PM
cncmike's Avatar
cncmike
Those parts retail for $1200. And maybe 4 hours labor. They are quoting more than double what it should be. By the way it took me over 100,000 miles to wear my rotors near the limit. And my belt and pulleys are worn but still going. That year of bike will usually go more than 150,000 miles without a major repair. Take it somewhere else.
Old Nov 28, 2018 | 11:44 PM
groupw's Avatar
groupw
Originally Posted by stkm04
.....Would it be better to keep the bike, put up the $4000 and $1000 in a year or two and "ride it to death"?
