Wanting to change my overall gearing on my 2015 Road Glide to 3.5 - 3.75 for better torque, I am planning to convert the belt to chain drive for easier setup and I am thinking about 24 transmission sprocket with either 55 or 58 rear wheel sprocket but I am struggling to find any information regarding stock gears teeth count on the primary, I know the front compensator sprocket is 34 T but I couldn't find any information whatsoever on the clutch gear tooth count. Please enlighten me folks! Thanks!!
You don't say what you are starting with and if it has cruise control. On throttle by wire bikes with cruise control, the cruise will be made inoperable when the engine rpm and transmission output shaft rpm are no longer within a pre loaded acceptable ratio. Each gear is loaded into the computer, my cruise works fine in 3rd,4th,and 5th, so if by accident you change your primary by one lower gear in the transmission, the cruise should still work.
I said it on first post, 2015 RGS, so it's TBW with 6th gear indicator and cruise. I am aware regear will screw that up but I have PV to reprogram the VSS and I also have the privilege of unlimited free of charge access to Centurion.
You sure did. I normally get annoyed when others are asleep while reading, this time it was MY turn. Will try to do better.
