Help...i have a 91 electra glide...the other morning i ran the battery down trying to start it..
decided to charge battery and fit cables for a trickle charger..after fitting battery back in bike it started just fine...but now have no blinkers back and front and no tail light....everything else working..
where do i start...
I understand theres no fuse box on this year..
Any suggestions..
Thamks
bob.
Not really anything to do with battery going flat just so happened this problem came up at the same time....two things....tail light bulb was just shot..
original 1991 bulb so not bad going,
Connector to rear part of loom bit corroded..quick squirt of w.d 40 and all is hunky dory !
cheers
Bob
