Electrical Problem
Old Jan 13, 2019 | 07:28 PM
Rogue8Man's Avatar
Rogue8Man
Default Electrical Problem
2011 FLHTC. Keep it on battery tender everyday when I get home. Replaced a battery after 9 months on previous battery. Only had a few min today but turned on ignition for about 2 min and reading was 12.7 volts. With multimeter on dropped around 10 volts as bike started. Ran up to 2000 rpms and it was at 14.3 volts. Been starting after night shift and it groans but starts (about 33 f). Should I worry? TIA
Old Jan 13, 2019 | 07:52 PM
Budda109's Avatar
Budda109
Sounds like a bad battery. The 14.3 shows it's charging. The 12.7 shows it's charged. The groaning shows you don't have the CCA's. If you have the tender connected you can stop at a battery's plus or most any auto store. They can hook to the tender connection. And can tell if the CCA's are what they should be. Most likely you have a dead cell. If the battrey is 9 months old you would be under warranty. Good luck
Old Jan 13, 2019 | 07:58 PM
Rogue8Man's Avatar
Rogue8Man
Sorry if I wasn’t clear. Had a Yausa for 9 months and it went bad. Replace with this battery about 3 months ago. What I’ve read bike running voltage should be btw “14.2 and 14.7”.
Old Jan 13, 2019 | 09:16 PM
tfi racing's Avatar
tfi racing
Why are you putting it on a battery tender every single day? Makes little to no sense to me...
Old Jan 13, 2019 | 09:20 PM
Rogue8Man's Avatar
Rogue8Man
Thought that is what you should do...
Kingglide549's Avatar
Kingglide549
The 33 deg is killing ya.
Why you starting it?
Old Jan 13, 2019 | 09:31 PM
Down South's Avatar
Down South
12.7 V = Full charged battery. What's the CCA of the battery?
On second thought that is resting voltage, 12.7 V. You mentioned having it on a battery tender. if you can, leave the battery tender unplugged for at least 12 hrs and check the voltage. That will be resting voltage. It should be at or very close to 12.7 V.
Old Jan 13, 2019 | 09:32 PM
95th 1200's Avatar
95th 1200
At 33 degrees 20w50 oil is like syrup, that's a big part of your problem. No harm in plugging in the maintainer daily, if the battery doesn't need any charging it'll just turn itself off. I'm in the same habit, when I'm not riding it gets plugged in.
Old Jan 13, 2019 | 09:36 PM
Vernal's Avatar
Vernal
When ever our bikes are in the garage they are on the tenders, still have the batteries we started with.
Old Jan 13, 2019 | 09:37 PM
Rogue8Man's Avatar
Rogue8Man
I’m starting it because work is over and time to go home. Transfer to days in 10 days thank goodness....
