Boom Box GTS Touch Screen Problems
Old Jan 30, 2019 | 11:45 AM
emdx3's Avatar
emdx3
Originally Posted by dDavid
How I the world does that help? lol
Lmao. No worries. Thanks for the input guys. I took the bike to the dealer and as typical, the glitch didn't occur while I was trying to show it to the service rep. Oh well. If it happens again, I'll record a video of it.
I also noticed there is a software update for the GTS system. You can find it here with instructions on how to update:
https://www.harley-davidson.com/us/e...m-box-gts.html
I just did the update, and hopefully I never see this glitch again.
Old Jan 30, 2019 | 08:22 PM
Down South's Avatar
Down South
Do you use the radio? How is your FM reception?
I use the FM radio on my 2019 Ultra all the time and the reception is good.
Old Feb 19, 2019 | 08:51 PM
emdx3's Avatar
emdx3
So it happened again today. It was really bugging out. I took the opportunity to pull over and video it. I also drove straight to the service department and luckily it happened right in front of the service rep. However, he said that if they can't reproduce it again on the lift, HD may not replace the unit. /eyeroll
The rep did say that it may be the switch housing shorting out. However, I think it's the touch screen. The right switch housing joystick alone can't switch between the info screen, nav, and music.
I dropped the bike off. I'll know more tomorrow.
Heres the vid:
Old Feb 19, 2019 | 09:01 PM
Red's Avatar
Red
So what's it doing? I watched the video twice. The only thing I saw is the touch screen doesn't like gloves. Mine doesn't either.
Old Feb 19, 2019 | 09:02 PM
K Melancon's Avatar
K Melancon
It is so sensitive that when I’m reaching with bare hands and I’m about 1/2” from screen it will select without touching. It may be your other fingers are hand may be too close to the screen and picking it up.
Nevermind just saw saw the video
Old Feb 20, 2019 | 12:02 AM
emdx3's Avatar
emdx3
I guess it may not be clear from the video alone. Normally touch response is superb, even with gloves on.
However, it has gotten into this mode a few times where it is bugging out like this. A few things are going on in this video:
1. It seems to not register touches, or they are registered at a delay. Normally, even with gloves on, a light touch is all it takes for instant response. When it's working correctly, the touch screen is very good, even with gloves.
2. When it does register the touch, often times it will register it on the wrong part of the screen (IE. if I click the middle of the screen, it thinks I hit the info button).
3. It will occasionally jump around from screen to screen, or activate random buttons on the interface. This even happened when the service rep started bumping the right switch housing with his hand, leading him to believe it may be the switch housing. Again, I don't think it's that. I think it's the touch screen.
Hopefully this clarifies it.
Old Feb 25, 2019 | 02:52 PM
emdx3's Avatar
emdx3
I just heard back from the service rep. Harley agreed to authorize a replacement GTS unit, which should arrive tomorrow at the dealer.
Old May 31, 2019 | 12:27 AM
MavEryck's Avatar
MavEryck
Default Same issue
I'm taking mine in for the same issue. Is your new system working better?
Old May 31, 2019 | 02:36 PM
emdx3's Avatar
emdx3
Yeah, my new GTS unit has not had this problem even once. Good luck!
Old May 31, 2019 | 06:30 PM
FrankEV's Avatar
FrankEV
Originally Posted by pw
I've got a 2019 Ultra Limited and have had no problems with my radio. A note to anyone interested in installing a CB radio themselves....After installing I verified it worked without doing the flash to the radio.
From what I understand the CB module will work without being Flashed. That prsumes you are using a 7 pin connector and a pugged in microphone and sound is through your speakers. However, If you want to be able to use a wireless headset, you need the WHIM module and that has to be flashed by a dealer. If by chance your UL had a factory installed WHIM, then there would be not problems adding the CB or using a wireless headset.
