Engine removal and install tips
Old Feb 11, 2019 | 04:47 PM
Mertoid's Avatar
Mertoid
Default Engine removal and install tips
I'm getting ready to swap engines in my 2011 Street Glide. It has 107k miles and I got a great deal on a takeout 2015 103 with a stage 2 and only 8200 miles on it. After removing the primary, exhaust, intake and all the ancillary bits, unbolt the trans, it looks like it should be tipped one way or the other and come out the right side. What tips do you guys have to do this swap?
Old Feb 11, 2019 | 06:11 PM
03 Fatboy's Avatar
03 Fatboy
I would replace the motor mounts, inner primary bearing, race and seal and flush out the oil lines and oil cooler (If you have one).
Old Feb 11, 2019 | 08:41 PM
Mertoid's Avatar
Mertoid
I replaced the front mounts 2 years ago, have new ones for the rear. Also putting new swingarm bearings in as well as a new belt and rear pulley. Once the back end is finished, I'll pull the engine. I did the IPB last fall since the seal was leaking. I'll replace the seal again this time too.
JDOrlando
May 6, 2018 09:09 PM
95yj
EVO
15
Jun 20, 2017 05:54 PM
marktruckee
EVO
Mar 30, 2016 06:28 AM
Rayvan
Sep 7, 2014 12:40 PM
trustyoldsteed
May 11, 2008 12:41 PM
