P&A IGN fuse location
Old Feb 17, 2019 | 07:35 PM
gearguru2002's Avatar
gearguru2002
Stage II
Default P&A IGN fuse location
Hi everyone,
I have a 2009 Road King that I am installing OEM heated grips on. The instructions say that there is one open side on the 2 amp P&A IGN location in the fuse block, but on mine, there is a terminal in that location with no wire. I removed the secondary lock (orange lock) and tried to release the terminal but it does not want to budge. Is there any trick to removing this so that I can install the switched power wire for the heated grips?
Thanks!
Old Feb 18, 2019 | 11:05 AM
IKnowNot's Avatar
IKnowNot
One side (power) should have a terminal already in it, the other should have been empty.
You are supposed to take that wire (if I remember, orange w/white stripe) and insert it into the terminal block in the empty position.
If you look at the terminal at the end of the wire you will see a very small tang (or barb, whatever you want to call it) that holds it in the block.
To remove a terminal from the block you would stick a small flat object (maybe jewelers screwdriver or similar) to push that tang away from the block, and pull the terminal out the back.
You may have to apply slight pressure to the terminal by pushing it from the back toward the front to make it easier to move the tang.
Hope that helps.
Old Feb 18, 2019 | 11:12 AM
dawg's Avatar
dawg
I thought the unused hole in that plug had a small white plastic dummy piece that inserts into the hole and gets removed when you use it, could be wrong though as it’s been a while since I’ve messed around in there.
Old Feb 18, 2019 | 02:41 PM
gearguru2002
Stage II
Hope that helps.
Thanks for the reply IKnowNot. The instructions that came with the grips said that one side would be open and there would not be a fuse in it, but that is not the case on my bike. The B side has an Orange/White wire on it, the A side has a metal connector in it with no wire attached. There was also a 2 amp fuse already installed. I removed the orange secondary lock and pushed the lock tab down using a jewelers screwdriver and was able to push the terminal back a little, but it will not come out. I think I will try to find something thin enough to actually go between the lock tab and the connector, to see if that would work. My fear was that there was some sort of internal bus bar holding it in, but there is no continuity to the terminal below it, so I am pretty sure that is not the case.
Old Feb 18, 2019 | 08:21 PM
IKnowNot's Avatar
IKnowNot
Sounds like someone has already connected something there to that fuse, and now you have the terminals confused.
I believe the one you are trying to remove is part of a multi-terminal strip, part of the “hot” end.
Check with a meter with fuse out to see which one is hot with the ignition switch in run position.
Then start tracing that orange/white wire to find out what is connected there.
(BTW, the “HOT” wire that feeds the fuse is red w/ black stripe, which could be anywhere along that multi-terminal strip, which is why it looks like it is not connected to anything.)
cookiemech
Milwaukee Eight (M8)
20
Oct 16, 2020 06:07 PM
D4tini
Jul 1, 2018 12:57 PM
dbubba
Mar 12, 2014 08:46 AM
dbubba
Electrical/Lighting/Alarm
Mar 10, 2014 10:08 PM
sws1
Jun 21, 2007 03:25 AM
