King or chopped
Old Jul 6, 2007 | 02:32 PM
JC650's Avatar
JC650
Default RE: King or chopped
If you have to stick a box on the back I would go for the more useful of the two.=King
Old Jul 6, 2007 | 02:38 PM
GMONEY220's Avatar
GMONEY220
If its gonna stay on your bike most of the time,go with the chopped,i think it looks bad azz to keep on.If your takeing it off once you get to your destination,get the king,cuz you can hold more gear.JMHO
Old Jul 6, 2007 | 02:56 PM
Bryan TTM's Avatar
Bryan TTM
was in the same place last fall....i choose the King TP...wished i'd chosen the chopped....that king will hold alot of heavy stuff and to me its too big now that i have it....in fact i'd swap it for a vivid black chopped if someone wanted...mines got everything includin custom dynamics leds
Old Jul 6, 2007 | 10:46 PM
BillyG0856's Avatar
BillyG0856
Im an EG Standard owner. I agree.....why not both!...lol
I like the looks of the 'chopped'....the 'king' is of more use, especiallywhen 2 up.
Calculizin'.......3 days of OT = BOTH!!! ...lol (of course that's after addin' some 'tunes'!....1 day OT)
Just gonna make sure my OT comes on COLD, RAINYNITES!!!!
Laterz yall!!
Billy G
Old Jul 7, 2007 | 01:48 AM
byersmtrco's Avatar
byersmtrco
Is it possible to run the King W/o the big pad? Maybe just the smaller pad like they use w/the chopped one. Do they make a bracket to mount the larger one a little lower? That might make it look more streamlined.
Old Jul 7, 2007 | 10:14 PM
bikemike's Avatar
bikemike
Thanks for everyones opinions and advise. I want with the king figuring since its detachable I can always just take it off. I also got the docking hardware to put just a backrest on it also You think H-D would make them the same but now its 2 different docking systems.
Old Jul 7, 2007 | 10:30 PM
kruzin's Avatar
kruzin
I went with the King pack and did the solo set up with removable mount. I put all the wiring for the lights and speakers in one 12 pin connector so I have only one connection to mess with. My antenna is mounted to the side rail so I do not have to mess with that. Love the comfort and tunes with this set up. In a couple of minutes I can remove and install the passenger seat when needed.
[IMG]local://upfiles/8414/21491BA26E254FD7B5D3540F976C60C3.jpg[/IMG]
[IMG]local://upfiles/8414/A2B90DD09666442CB04E83FA2018AAF0.jpg[/IMG]
[IMG]local://upfiles/8414/171DB5D656104DF48AE62EE33DB2FA03.jpg[/IMG]
[IMG]local://upfiles/8414/C3FB39DA532940EAB86A8CA8AE51D3C3.jpg[/IMG]
[IMG]local://upfiles/8414/073DA3AC28A6410A99D3EEB5B0FD8C46.jpg[/IMG]
Old Jul 7, 2007 | 11:46 PM
Harleypingman's Avatar
Harleypingman
Kruzin: I have a King TP on a two-up detachable rack and an aftermarket TP on a solo detachable rack, but I've been considering mounting the King on the solo. Is it comfortable with the large backrest andare the armrestsin the way getting on or off the bike?
Also, props to you for redoing the wiring connection with a 12-pin connector. Did you use a Deutsch connector?
Old Jul 8, 2007 | 12:07 PM
kruzin's Avatar
kruzin
The backrest is very comfortable. It isn't any harder to get on and off than with having a regular backrest. And yes I did use a Detusch connector. We have them for work so I just took the tool kit and wired up my own connector. By the way I also installed an amp for the rear speakers to pump up the volume. Already have the Hog Tunes amp for the front so I needed to add the other one to equal out the volume. The amp is also wired into this connector.
mesquite
Jun 21, 2013 08:06 PM
MNHarley
Apr 3, 2013 08:37 PM
jd140400
Apr 16, 2009 09:06 PM
SLC Rider
EVO
Mar 10, 2008 09:15 PM
1999cobra
Jan 26, 2006 08:52 PM
