Confused, battery acting up
Old Feb 28, 2019 | 07:06 AM
whyrzwaldo's Avatar
whyrzwaldo
Originally Posted by nutsandbolts5212
When load testing the battery it should not drop below 10, if it does, you need a new one.
Ride safe!
^^^^^^^^^^^^^^^ Yeah that! +1
Old Feb 28, 2019 | 07:14 AM
ORradtech's Avatar
ORradtech
Originally Posted by Pantera99
28,500 miles. Just had her out last week. Doesn't sit for more than a week or 2 at a time. Had been getting the occasional 'clunk' when restarting hot. Then I was advised to hold starter button longer & that seemed to help. Think I'll start with cleaning the connections really well & go from there...but I know with all of my Japanese bikes a fresh battery was normally all that was needed.
Tight connections are important but a dirty/corroded connection will still cause problems no matter how tight it is. Clean all connections until they are shiny metal then tighten them up. Maybe use some dielectric grease to protect the connection. And remember, every wire has two ends, clean and tighten both.
Old Feb 28, 2019 | 08:45 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Get the battery load tested.
Old Feb 28, 2019 | 12:54 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Originally Posted by Brewmany
The idiot gauge is volts, not amps.
I thought the same thing, too funny!!
Ride safe!
Old Feb 28, 2019 | 08:07 PM
Pantera99's Avatar
Pantera99
Update: well found a bunch of wires attached to battery posts & they're marked 'heated clothing '. Removed all of them so only main cables & tender cables are attached now. Cleaned everything, topped off w tender read 13.55, disconnected tender read 12.5, on startup battery dropped to about 10. Revving up after start read about 14.03. Test ride tomorrow. Thanks for all the help/ suggestions!!
Old Feb 28, 2019 | 08:08 PM
danzio's Avatar
danzio
I ride an '07 Ultra and have had issues with keeping batteries alive for more than 2 -2 1/2 years. I also was experiencing hard starts on occasion and more often when heat soaked (after a fuel fill or other short stop, etc.). After going through a few different areas of troubleshooting, including new All ***** starter clutch I still couldn't get the battery to last.
Finally decided it was related to the crank position and depending on the stroke cycle the entire starting process was putting too much stress on the start-up from starter to battery. So since I was considering a cam upgrade anyway, I went with the S&S Easy Starts and I've not had a hard start since. My battery is cranking fine and I haven't had a single hard start since. Over 2 years now. And the improved performance was a bonus. Or the other way around but it was a great upgrade with multiple benefits.
Old Feb 28, 2019 | 10:34 PM
hattitude's Avatar
hattitude
If the tender was attached, the 13.55v you measured was the tender
For the 12.5v to be accurate, you need to disconnect any charging source, disconnect the battery from the bike (so there's no parasitic draw), and then let the battery rest for at least 30 minutes before testing the voltage.
The 14.03 volts you measured is charging voltage of the running bike..
The best way to know if your battery is good/bad for sure, is to remove (or disconnect) the battery from the bike and use a battery load tester on it.... If you don't have one, most good parts stores have one and they'll test your battery if you bring it to them.
I got 7 years on 2003 OEM battery.... All battery makers must not be using as pure lead in the plates as the old days, I haven't got close to that since.... Here in SoCal, three years for me has been a good battery....
Old Mar 1, 2019 | 06:05 AM
danny54's Avatar
danny54
Easy fix, Replace battery with new one.
Old Mar 1, 2019 | 07:17 AM
Pantera99's Avatar
Pantera99
Guess I should mention here thst it's my 17th wedding anniversary today & took today off to have a nice ride with my wife. Have no problem buying a new battery but all that's available locally is batteries plus w 400 cca's. Already decided on a Mega Crank but that doesn't do me any good today. If my current battery gets me thru this weekend I'm satisfied.
Old Mar 1, 2019 | 08:41 AM
nutsandbolts5212
Congrats on your 17 yr anny. If you are having that much of a problem with the battery I would be very careful of traveling far. That would suck if you and the wifey stop for lunch and a couple pops and decide to head back and your bike won't start. Just saying, sometimes it's better to be safe then sorry.
Ride safe!
BTW, I run Mega Cranks in my bikes, love them. Batterymart.com is where I get them, great prices and free shipping.
