HK update CD???
Old Mar 8, 2019 | 06:51 PM
Bulrid8's Avatar
Bulrid8
Default HK update CD???
Does anyone happen to have an update CD that works? I have burned 5 at slowest speed I could and it still wont read the disk.
Old Mar 8, 2019 | 11:31 PM
IKnowNot's Avatar
IKnowNot
I doubt speed is your issue, but it is recommended using 8x or less.
There have been several updates to the optical disk writing specifications since the HD HK software updates were released, and even worse, many modern programs don’t tell you or give you a choice as to what format they are using. That is why you were told in in Audio Forum to try and use an older computer to burn them. (As I recall I used an XP machine, which has since fried.)
The instructions call for
“… standard format (HFS Plus/ISO 9660), iTunes (Audio CD), or MP3 (ISO
9660).”
You might search to see if there is a way to burn the CD in one of those formats on your computer, or maybe give some info as to how you burned those 5 disks, i.e.
What operating system
What program was used
What settings in the program were used.
Maybe someone will be able to help you then.
Old Mar 9, 2019 | 01:01 AM
LQQK_OUT's Avatar
LQQK_OUT
This doesn't help the OP, but for people looking for the update, you should be able to find it on the following link
https://www.harley-davidson.com/us/e...an-kardon.html
Old Mar 9, 2019 | 01:51 PM
Bulrid8's Avatar
Bulrid8
I have burned 10 disks now and none will work. All different programs ie: IMG BURN, NERO, ROXIO. All speeds from 2x-8x. Made sure it was burning to ISO. Still no luck.
Old Mar 9, 2019 | 02:32 PM
IKnowNot's Avatar
IKnowNot
Again, the original ISO 9660 (1998) standard has been updated several times, and some revisions were still called 9660.
Nero should be able to do it ... so should some of the others, but they default to newer formats.
Been a while since I used it, but you want to look for the file/options/expert tab (something like that)
There should be an ISO tab somewhere in there, you want to uncheck all options (like Joliet, UDF, etc. You want just the original ISO 9660 . (this may be in the Relax Restrictions area)
If there is a choice for msdos (don’t think Nero has that) you could check that as well.
Old Mar 9, 2019 | 02:47 PM
Bulrid8's Avatar
Bulrid8
Thanks, I did burn the first one at ISO 6990 only. Would not work. I am installing an older version of nero now, to try that.
Old Mar 9, 2019 | 03:37 PM
IKnowNot's Avatar
IKnowNot
Just a thought here, you are using CD-R disks?
The instructions are on the page that LQQK OUT posted the link to. (Glad HD restored that page, it was down for a while.)
Old Mar 9, 2019 | 03:45 PM
Bulrid8's Avatar
Bulrid8
Yes, I am using CDR discs. I have burned 15 discs at all different speeds with 5 different burner software. None will work. Guess I will be calling dealer Monday to see if they have one.
Old Mar 9, 2019 | 07:25 PM
IKnowNot's Avatar
IKnowNot
In for a penny, in for a pound …
One last thing:
Try to burn this image to a CD-R. (This is an .iso file !!! You need to change the extension from .mpg to .iso because the site would not let me zip it!)
File Type: mpg
Last edited by IKnowNot; Mar 9, 2019 at 08:21 PM. Reason: trying to upload the attachment
Old Mar 10, 2019 | 12:53 AM
IKnowNot's Avatar
IKnowNot
Another thing;
after all this and the problems I had finding and uploading the .iso.
You said you are using a CRR, but that is incorrect.
You need to be using a CD-R (that is CD minus R) not a CD+R.
There is a difference.
