Throttle body question
Old Mar 10, 2019 | 10:20 AM
hdrider98ci's Avatar
hdrider98ci
Default Throttle body question
Just purchased a 15 RG and want to wipe out the inside of the throttle body( looked like some oil from the breather in it) , How do you open the butterfly without the bike running or is this not possible ? Also id there a way to tell if the Ecm has had a download done because the bike has V&H pipes and a different air cleaner and the plugs are very white ?
Thanks
Old Mar 10, 2019 | 11:47 AM
purpledeuce's Avatar
purpledeuce
I think if you push on it, it will open
Old Mar 10, 2019 | 01:48 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Thought I read somewhere on this forum about not manually opening the plate on the fly by wire throttle body, this could take them out of calibration.
Old Mar 10, 2019 | 02:34 PM
MotoJockey's Avatar
MotoJockey
Uh-oh........
Old Mar 10, 2019 | 03:41 PM
skydude426's Avatar
skydude426
Push it open by hand.
Old Mar 10, 2019 | 08:44 PM
RFC1962's Avatar
RFC1962
Just push it open and make sure it closes when you're done. It recalibrates itself every time you turn on the run switch.
Old Mar 10, 2019 | 09:32 PM
1Canuck's Avatar
1Canuck
Have not tried this, but with ignition on, run on, why won't it open when throttle applied
Old Mar 11, 2019 | 08:26 AM
Vernal's Avatar
Vernal
The throttle plate is positioned by a small electric motor, I read a post quite a while ago that said you could damage plastic gears between the plate and motor if you forced it. Don't know if that was true but I have pushed on one of ours and it didn't move so I quit trying.
Old Mar 11, 2019 | 08:45 AM
skydude426's Avatar
skydude426
I’ve opened mine several times by hand. They have a strong spring so they don’t just push open easily. At the same time, do with the bike off so there is no power to the motor and sensors built into the actuator. If it makes you feel better you can also disconnect the electrical connector so you know it’s disconnected from the bikes power and control systems. Your not going to knock it out of calibration. The ECM probably calibrates off the closed position every time you power up the bike.
I just sent sent mine to Fuel Moto to have my throttle body ported. I can tell they did the work with the butterfly in place so they had to open it and hold it open with a tool to do the work. Here it is still off the bike.
Old Mar 11, 2019 | 09:11 AM
Vernal's Avatar
Vernal
Next time I'll push harder
