antennas
Old Mar 21, 2019 | 03:34 PM
norm2001ultraclassic's Avatar
6th Gear
Default antennas
I bought a few months ago a 2001 Ultra Classic. It has the two antennas on the tour pack. I want to remove the CB one as I will never use it and maybe replace the radio one with a stubby one.
Which antenna is the CB one? Left or right side? The one on the right side has a large spring above the mount while the other on doesn't.
Thanks for any insight!
Old Mar 21, 2019 | 04:08 PM
GalvTexGuy's Avatar
GalvTexGuy
Right is CB.
Old Mar 21, 2019 | 07:23 PM
skinman13's Avatar
skinman13
the large "spring" is the CB antenna loading coil used to tune to a short antenna
Old Mar 21, 2019 | 08:02 PM
6th Gear
Thank you guys!!!!
Old Mar 21, 2019 | 08:09 PM
Hoginedgewood's Avatar
Hoginedgewood
I found a short fat one at the auto parts store. About 4" tall. Probably fit both of yours and look better than trying to remove 1.
Old Mar 22, 2019 | 09:54 AM
hawg50's Avatar
hawg50
i cut about a foot off of both of mine,looks a lot better.
Old Mar 22, 2019 | 10:54 AM
6th Gear
Good ideas! Never thought about just cutting to shorten. They just really a tall whips and really wobble at idle as the bike shakes a lot. Figure to remove the CB on but cut down the radio antenna for better looks.
Did cutting down effect reception much? I actually don't listen to the radio much anyway. I have a few old cassette tapes that I play. Would be interested in streaming but the radio and bike are 2001 and don't have that capability.
Old Mar 22, 2019 | 03:30 PM
whiskeyfire's Avatar
whiskeyfire
I think the 2001 has a port next to the tape player, it should be a 3.5mm port. I use that and my phone for music.
Old Mar 22, 2019 | 04:02 PM
VA_Larry's Avatar
VA_Larry
If you're going to toss the CB antenna I'd be interested in trying on my 2015 to see if the service improves.
Old Mar 22, 2019 | 09:06 PM
skinman13's Avatar
skinman13
you don't want to cut the CB antenna shorter if you plan on using the CB transmitter...it will blow out the final transmitter drivers and ruin the CB
