2008 FLHX Electrical Problem?
Everytime I ride this incident Happens...A sudden loss in power ... the engine goes off along with the stereo and headlight... the start button doesn't start..then I switch the ignition to off and then on again along with changing the handlebar position and power is back on and Everything works again until the next time the bike feels like losing memory again.... it happened when the bike was not moving and when it was on the road as well...
Any Ideas how should I approach this? I'll get the Trouble codes and share it ..
Thank you
Do you have an electrical diagnostic manual for your year bike? Factory service manual?
I would first check for codes, then check fuses, and then check the wires from the ECM to the handlebar harness for continuity, resistance, and grounding. THEN i would start with the handlebars, and since they an aftermarket install, there's a good chance that the problem lies within them. Some will probably say, why would you start from the back at the ECM and then work to the front, if you know the handlebars are the problem? Well because its way easier for me to rule out any ECM issues, fuse issues, and other issues and then go to the handlebars, because that is gonna be some labor breaking the handlebars down. You can also follow a troubleshooting process in the EDM and rule out from there, because that's exactly what Harley is going to do if you bring the bike to the dealership.
Here you go, did the homework for you: http://www.sunnymeadcycles.com/files...iagnostics.pdf
Download on your PC or Mac and you now have it. Good luck and post back your results so others can learn.
Ride safe!!
Ride safe!
Ride safe!
Any recommendation how can i make sure it is the ignition?
That's why I'm leaning towards bad ignition ****/switch..
Thanks to all the great ppl who are suggesting and answering... God bless you
If you can recreate it in the garage leave the ignition switch on and don't move the bars then check power to Accessory, Cruise/Brake or P&A fuse to see if they lost power. If they did the switch or it's connector would be the culprit.
