found this on 1130cc.com
Old Jul 8, 2007 | 05:56 AM
ricaroo's Avatar
ricaroo
Default found this on 1130cc.com
2008 Ultra? [/align][hr]
105th
Everything you ever wanted in a big, luxurious touring motorcycle – now with just a little bit more. The Ultra Classic® Electra Glide® model provides the ultimate in touring comfort and performance. An 80-watt/amplifier, Harman/Kardon® Advanced Audio System. Vented lower fairings with integrated storage compartments. Luxurious comfort-stitch Touring saddle and passenger backrest. The smooth-shifting 6-Speed Cruise Drive™ transmission. And much more.
Plus, for 2008, the Ultra Classic Electra Glide model is available with factory-installed Brembo® brakes, with optional ABS. A six-gallon gas tank and adjustable right and left fairing-mounted air deflectors are also new for 2008. The best part is, it all comes standard with the undeniable sound and feel of the Twin Cam 96™ engine. In other words, it’s 100 percent Harley-Davidson.
The 2008 Ultra Classic Electra Glide model is available in serialized, limited-edition 105th Anniversary styling, featuring special Anniversary Copper and Vivid Black paint, a tank cloisonné with Copper Bar & Shield, a copper vinyl insert on the seat and pillion and more.
GENERAL INFORMATION
Manufacturer Harley-Davidson®
Model Year 2008
Model FLHTCU Ultra Classic® Electra Glide® 105th Anniversary Edition
Price * Request a Quote
Color Copper/Black
Stock Number: 101
Miles/Hours N/A
POWERTRAIN
Engine Air-cooled, Twin Cam 96â„¢, pushrod-operated, overhead valves with hydraulic, self-adjusting lifters; 2-valves per cylinder
Displacement 96 ci (1,584 cc)
Bore x Stroke 3.75 x 4.38 in. (95.25 x 111.25 mm)
Compression Ratio 9.2:1
Torque 92.6 ft. lbs. (125.57 Nm) @ 3,500 rpm
Fuel System Electronic Sequential Port Fuel Injection (ESPFI)
Exhaust Chrome, cross-over exhaust with dual mufflers and taper end caps
DRIVETRAIN
Transmission 6-Speed Cruise Driveâ„¢
Clutch 9-plate, wet
Lubrication Pressurized, dry-sump
Final Drive Belt, 32/66 ratio
DIMENSIONS
Frame Mild steel, square-section backbone with twin downtubes
Length 98.3 in. (2,496.82 mm)
Width 39 in. (990.6 mm)
Height 61 in. (1,549.4 mm)
Wheelbase 63.5 in. (1,612.9 mm)
Seat Height Laden: 27.3 in. (693.42 mm)
Unladen: 30.7 in. (779.78 mm)
Ground Clearance 5.1 in. (129.54 mm)
Dry Weight 814 lbs. (369.22 kg)
Fuel Capacity 6 gal. (22.71 l)
BRAKES / WHEELS / TIRES
Suspension Front Forks: 41.3 mm telescopic, cartridge-style damping; 4.6 in. (116.84 mm) travel
Rear Shocks: Air-adjustable; 3 in. (76.2 mm) travel
Brakes 32 mm, 4-piston fixed front and rear calipers, patented, fixed rotors
Front: Dual 11.81 x 0.2 in. (299.97 x 5.08 mm)
Rear: 11.81 x 0.28 in. (299.97 x 7.11 mm)
Tires Front: D402F NW (MT90B16 72H)
Rear: D402 NW (MU85B16 77H)
Rake 26°
Trail 6.2 in. (157.48 mm)[/align]
Old Jul 8, 2007 | 09:45 AM
SSJ's Avatar
SSJ
Default RE: found this on 1130cc.com
6 gal tank would be sweet adding some more miles betweem stops.. I'm interested in seeing some of the new colors like the golden/black glow colors.
Old Jul 8, 2007 | 09:58 AM
gunrunner's Avatar
gunrunner
Could be next year will feature "105th Annv" models of all styles along with the regular models and abs has been talked about before, its not new harley has been in useing it on police bikes for several years now.
EKESS
Motorcycles For Sale
Jun 28, 2011 07:01 PM
norskehd
Feb 13, 2008 07:01 PM
AZ Rider
Jul 8, 2007 03:35 AM
AZ Rider
Jul 7, 2007 10:06 PM
