Not satisfied with lower fairing install
Old 04-09-2019, 09:39 PM
6113_'s Avatar
6113_
6113_ is offline
Received 32,998 Likes on 12,901 Posts
Default Not satisfied with lower fairing install
I bought the HD lower fairings when I bought the bike and put them on myself. I'm not happy with either my install, or the way they fit, either way if you can offer some advice, please do so.
I've looked at the Ultra's, etc. that have them installed at the factory and they seem to "fit" better than mine, so maybe I have them out of position somehow.
In the pics, you'll see that they fit snug at the outer radius but as the top piece approaches the bike there is a "wedge" I would call it in the seam that opens up. The gap is not uniform as I think it should be. I've taken them on and off a couple times but nothing I've tried so far seems to improve them and it's like on both the left and right fairings.
Old 04-09-2019, 10:39 PM
Sturgis67's Avatar
Sturgis67
Sturgis67 is offline
Yeah something is not quite right there. Looks like you have something tweaked a bit. Not sure I'm really much help, but maybe you could loosen or disconnect the bottom and push the bottom forward a bit to close the gap on top and tighten before you connect the bottom.
Old 04-09-2019, 10:44 PM
6113_'s Avatar
6113_
6113_ is offline
thanks, and you're right, it's something. It seems pretty straight forward but the gap is almost identical on both sides, you'd think I would at least get one or the other close.
Old 04-09-2019, 11:37 PM
fenwick's Avatar
fenwick
fenwick is offline
how do they fit together before they are installed?. Are they tighter or still the space
Old 04-10-2019, 06:40 AM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
That would definitely **** me off. I have a set of factory lowers that I plan to install as soon as i get a factory crash bar. I think i ll put them together off the bike first to see how they fit. When I took them off my buddies bike i don't recal there being any unevenness
Old 04-10-2019, 11:19 AM
sixguns's Avatar
sixguns
sixguns is online now
Received 1,458 Likes on 755 Posts
As I recall the cap has some alignment tabs to engage into their respective slots. Its been awhile since I installed mine. But yes yours are not right. here is a pic of how mine fit
Old 04-10-2019, 11:26 AM
jory434's Avatar
jory434
jory434 is offline
Loosen your hardware just a little and kind of bump them around until they "settle" onto the crash bar a little better. Pardon my description, but they may be just a tiny bit out of position and still tighten down, but not align very well.
Old 04-10-2019, 01:09 PM
whiskeyfire's Avatar
whiskeyfire
whiskeyfire is offline
I had the same problem, the bottom of mine were not positioned properly at the crash bar. They were hitting it, I wiggled them around until the top fit tightly. Good luck, you'll get it. There should be no gap prior to tightening the screws, so don't use the screws to "pull" it together.
Old 04-10-2019, 03:25 PM
groupw's Avatar
groupw
groupw is offline
Originally Posted by 6113_
..... but the gap is almost identical on both sides,
...... which point to an install issue.
..... loosen all contact points @ the crash bar & see what moves & what doesn't
... retighten accordingly
laman22
Audio Systems
08-25-2021 05:03 PM
AFONE
02-21-2015 02:54 PM
Tweeter2148
12-02-2014 09:53 AM
sporty06
05-04-2010 04:58 PM
newby
10-10-2007 10:17 AM
Quick Reply: Not satisfied with lower fairing install
