HD BOOM Audio Stage II
Old May 10, 2019 | 01:31 PM
BackInDaSaddle's Avatar
BackInDaSaddle
2nd Gear
Default HD BOOM Audio Stage II
Gave myself a BD present, upgrading my '18 Road Glide stock audio, to the BOOM Stage II. Sounds great at low city speeds, but at cruising altitude, sound fades in and out. Replaced my USB cable, tested it with new music player, still fades at 60mph or higher [mostly higher...] Maybe I got a sketchy amp. Any thoughts or anyone have a similar problem ?
Old May 10, 2019 | 01:37 PM
GalvTexGuy's Avatar
GalvTexGuy
When you say "fades in and out", do you mean the volume gets lower and higher or do you mean wind and exhaust noise overwhelm the music?
Old May 10, 2019 | 01:43 PM
BackInDaSaddle
2nd Gear
Volume fluctuates lower and higher. Not a wind or pipes issue. At 75mph, I can tuck forward behind the Klockwerks windshield and can hear it fade in and out.
Old May 10, 2019 | 01:51 PM
GalvTexGuy's Avatar
GalvTexGuy
Well, in that case have you checked to make sure you don't have a route loaded into Navigation with the prompt volume turned down and the girl keeps telling you to make a u-turn?
Old May 10, 2019 | 01:59 PM
BackInDaSaddle
2nd Gear
Naw, don't have any preconfigured routes in there yet. Only have 6K on it since August. Either down the west coast on 1/101 and up thru central California, or eastern parts of Oregon, Washington, and a wrong turn into Idaho.
Old May 10, 2019 | 02:06 PM
GalvTexGuy's Avatar
GalvTexGuy
Check it just in case. You never know with these new-fangled computer controlled motorcycles. Did you install it? If so, did you have the dealer do the DTII amplifier calibration?
Old May 13, 2019 | 09:31 PM
BackInDaSaddle
2nd Gear
Dealer installed it. Went back and talked to them. They think it has to do with the Speed Volume Control. They wanted me to turn it off and see if that stopped the fading. It did. So, they are talking with HD for a fix. That's what happens when you have 13 yr old write your code.
84Country
Audio Systems
11
May 11, 2019 10:36 AM
BackInDaSaddle
May 10, 2019 01:28 PM
SAFrog
Milwaukee Eight (M8)
11
Aug 31, 2017 05:50 AM
cash64
2014-2024 Touring Models
30
May 23, 2016 02:40 PM
2807
Audio Systems
Jul 4, 2015 12:45 PM
