Bump Stops
Old Jun 3, 2019 | 06:41 AM
Drtumolo's Avatar
Drtumolo
I currently have an air ride system on my 2016 streetglide. Aired out all the way the shocks are 9.5" long and there is no rub anywhere when aired completely out. With the reputation of pro-action or suspension technology shocks I would not think either company would supply a shock that would cause tire rub. Did you call the shock vendor to discuss your issue with them?
Old Jun 3, 2019 | 09:11 AM
FrankEV's Avatar
FrankEV
OK, here is the story. In one word...ME!
Just was in the process of getting ready to replace the 11" ST shocks with the 12" OEM shocks. Got as far as getting the rear wheel jacked up off the ground. Decided to see if there was any adjusment left on the ST shocks. Well, to my supprise I wasn't even halfway up on the adjustment. With the load off the shocks the adjustment was far eaiser then when under even just the weight of the bike.
So running it up as stiff as possible, I took it out solo and hardly noticed much difference from when they were adjusted very soft. I'm aware that shorter shocks are inherently stiffer anyway., so there didn't seem to be much difference.
Then we when out 2-up and there was no tire rub, and only when hitting a severe bump there was a slight chirp. That would happen on my Heritage as well so we can live with that and just try to avoid those hard bumps and potholes.
Looking at the setting charts for the OEM 12" shocks, the adjustment was 0 for me alone, and 23 for us 2-up. This kind of told me for us I will have to keep the ST shock fully stiff for 2-up riding and deal with the stiffness when riding solo since making changes to the ST shocks is not as easy as shocks with a **** adjuster.
Looks like to ease the stiffness situation a little, a seat mod by MCC may be in order...cheaper than Air ride.
I think I can say we can put this thread to bed!
FrankEV
Jun 3, 2019 03:54 PM
jayel79
Mar 23, 2009 09:42 PM
DPete
Apr 14, 2008 04:05 PM
sweet07
Mar 7, 2008 04:39 PM
TedMan
Jul 11, 2006 11:39 AM
