9/16 Master Cylinder for Single Disc Bagger Conversion
In converting to single front disc setup what HD models and years that have 9/16 front master cylinder bolt right up to my 07 Street Glide.
From what I have read Dynas and Softails use 9/16 bore....had an 09 Dyna and from what I remember the brake master/setup at the bars looks the same...with obvious longer switch housing on my bagger for the radio buttons.
yup...used one from a softail (9/16" from the 11/16")for the conversion on our 05' RK (to the 11.8" disk) ...you'll need a new brake line also to get rid of the tee for the dual setup ...
try and find one from a dyna, sportster or softail of the same year or real close to it .... https://www.ebay.com/sch/i.html?_fro...aster+cylinder
good luck ... pats sportster 019
