D&d exhaust interference
Old Jun 21, 2019 | 08:57 PM
bdtaylor1979's Avatar
bdtaylor1979
Default D&d exhaust interference
I have a 2014 Ultra limited that the previous owner put d&d exhaust. Today I attempted to flush the clutch fluid and couldn't get the cover off of the side of the transmission to get to the bleeder because the exhaust is too close to the cover. Anyone with d&d exhaust run into something like that and have a way to get the cover off without removing the exhaust?
Thank you for any advice!
Old Jun 21, 2019 | 09:00 PM
Ryan42's Avatar
Ryan42
Most exhaust systems on that particular bike blocks the transmission cover to pull it off haven’t seen one that doesn’t. To drain the tranny you just drop the bolt on the bottom or If you want to take that cover off takeoff the exhaust
Old Jun 21, 2019 | 09:24 PM
GalvTexGuy's Avatar
GalvTexGuy
I had a V&H Pro Pipe that blocked the cover. Since then, I've gone back to the stock exhaust, which does not block the cover.
Old Jun 21, 2019 | 10:29 PM
1 2 many's Avatar
1 2 many
I also have D&D. and would have to pull the exhaust to service the clucth fluid
Old Jun 21, 2019 | 10:49 PM
bdtaylor1979
I've thought about getting a stock decatted exhaust with some aftermarket slip ons because I like the look of dual mufflers better and it sounds like I wouldn't have to remove the exhaust the change the clutch fluid.
Sounds like a pain in the butt. You'd think that d&d would have made a better design than that.
T Man
Apr 29, 2017 12:59 PM
DoubleEagle
Jan 21, 2016 05:02 PM
jim70
Shovelhead
May 24, 2013 01:58 PM
Barz
Apr 23, 2011 03:04 PM
Trek
Exhaust System Topics
Aug 10, 2008 09:59 PM
