Cam Gears
Old Jun 27, 2019 | 04:26 AM
NELS's Avatar
NELS
Default Cam Gears
Friend has a 2000 RK and wants to change to gear drive cams. Question is he doesn't want to change cams ,just wants to change to gears. Is this possible . Can I just use gears on his stock cams?
I've done the cams, lifters and cam bearings on my 96 in. but not sure if I can do what he wants.
I know i'll probably get the " as long as your in there you should " but this is his decision, not mine.Although I'll make suggestions Bike has 30k so not used much but in excellent shape.
Old Jun 27, 2019 | 04:57 AM
Ultra 99's Avatar
Ultra 99
I don't believe that's possible. The cams have to be specifically made to be used with gears.
Old Jun 27, 2019 | 05:19 AM
NELS's Avatar
NELS
Thank You, Why I asked is I've seen gear sets online but they didn't show having to replace the cams.
Old Jun 27, 2019 | 05:44 AM
skid_pimp's Avatar
skid_pimp
Why go to the expense and not swap the cams? To each his own. I'm fairly certain that you have to have cams built for gear drive vs, chain drive. But then the gears are replaceable if needed, which is likely why you have seen replacement gear kits.
Old Jun 27, 2019 | 06:35 AM
NELS's Avatar
NELS
Kinda gonna answer my own question, After looking at the stock 96 cams , the gear is pressed on an the replacement gears I seen are keyed.
I was just going to replace the chain followers but he asked about changing to gear drive is why the question came up.
Old Jun 27, 2019 | 07:51 AM
rigidthumper's Avatar
rigidthumper
Chain drive cams rotate the same direction, and gear drive cams go opposite directions, so no. You would have to have a set of blanks ground to your current cams specs, but made for gears.
Old Jun 27, 2019 | 09:42 AM
LazySundays's Avatar
LazySundays
S&S 475 is a stock grind for gear drive conversion. Seams like a lot of money for very little benefit though.
A set of Cyco tensioner shoes and new bearings would get him down the road for much less money and be extremely reliable and quiet.
producer
Exhaust System Topics
May 1, 2013 06:13 AM
sluggo99
Aug 24, 2010 09:54 PM
roofer
Ironhead
Mar 4, 2008 10:03 PM
broke joker
Apr 3, 2007 08:40 PM
MAX EVO
Nov 28, 2006 02:23 PM
