Inner primary Bearing tool
Old Jun 27, 2019 | 07:28 AM
miketv84's Avatar
miketv84
Default Inner primary Bearing tool
Question, would anyone recommend buying the fancy JIMS bearing install tool that's $150 to do the inner primary bearing or will the harbor freight $60 arbor press do just fine ?
I want to do the job right but $150 is alot for one time use. Also if anyone is selling the JIMS tool, I would buy it. Thanks !
Old Jun 27, 2019 | 07:38 AM
RANGER73's Avatar
RANGER73
Post a link to the HF tool
Old Jun 27, 2019 | 07:39 AM
RANGER73's Avatar
RANGER73
And what year bike are you working on?
Old Jun 27, 2019 | 07:41 AM
miketv84's Avatar
miketv84
2007 Road king
Old Jun 27, 2019 | 08:19 AM
Zerk's Avatar
Zerk
I've done it threaded rod and sockets. Getting an actual set of spacer would be nice. A press has been on my someday list for years.
Old Jun 27, 2019 | 08:51 AM
skinman13's Avatar
skinman13
I used a $100 HF 12 Ton press to remove and replace all the engine case bearings, cam-plate bearings, and the inner primary bearing. Since I already had the clutch basket and compensator off, it did not take much more time to take off the rotor and pull off the inner primary cover to change the bearing. I cut the walked-in race off and I borrowed a George's Garage inner race tool to install a new one. Unlike the specialized tool, a press also has lots of other uses.
Old Jun 27, 2019 | 08:54 AM
miketv84's Avatar
miketv84
Was the inner race causing a leak or you just saw it didn't look good ?
I bought a gloss inner primary so that's why I'm pressing a new bearing. But I have a leak also, not sure if it's the IPB. I'm also planning on changing the selector shaft seal.
Old Jun 27, 2019 | 01:51 PM
Tarkus60's Avatar
Tarkus60
I used a harbor freight 20 ton press....pop right out; pressed new one in!
Old Jun 27, 2019 | 01:52 PM
skinman13's Avatar
skinman13
It had walked in and was contacting the mainshaft oil seal so I cut it off and put on a new one.
Old Jun 27, 2019 | 01:54 PM
Tarkus60's Avatar
Tarkus60
Also I bought the Baker IPB so no more race.....that was 10k miles ago!
