front and rear fender tips
Old Jun 29, 2019 | 10:10 PM
FLHTKCU's Avatar
FLHTKCU
Default front and rear fender tips
Hi
For my 2016 ultra classic limited
I just replaced the standard brake and running lights with the Custom Dynamics Probeam for the brake light and tour pack lights.and a new brake light assembly.
I didn't realize that I had the modules switched around and put the brake light one in the tour pack wiring and the tour pack one in the brake light wiring. Since nether worked, I called CD and in only about 30 seconds I got a Service rep. After I gave him my bike type and the package numbers ( he wanted to make sure I got the correct ones), He told me that I might have switched where the are to be plugged in. He waited till I plugged them in the proper place to see if they did work.
I was very impressed with the service i got.
i also replaced the front turn signals with the brighter LED ones
Now my question:
Looking at the front and rear fender tip lights. Are they just reflectors or really lights? I can't find any wiring for them unless they are between the fender and the tires. Since I'm making the stock lights brighter, I'm wondering if I could change those too
mike
Old Jun 29, 2019 | 10:18 PM
GalvTexGuy's Avatar
GalvTexGuy
Yes, they are lights and they can be replaced.
Old Jun 29, 2019 | 10:25 PM
Jmkelly's Avatar
Jmkelly
Default lights
They really are lights. I went all led this winter. They are rectangular and super bright. Just hold the plug when you insert the led makes it easier to get in.
Old Jun 30, 2019 | 02:16 AM
sixgun95's Avatar
sixgun95
Which LED bulbs fit the fender tip lights?
Old Jun 30, 2019 | 02:26 AM
Jmkelly's Avatar
Jmkelly
https://www.customdynamics.com/front...arley-davidson
these fit my 06 Electra Glide. Can not be happier. I got the Amber for the front and the red for the rear.
Old Jun 30, 2019 | 03:39 AM
xcbullet's Avatar
xcbullet
The rear CD doubles as a brake light also on my year. There was already a spot to plug in the brake light function, not sure if the newer stretched out ones are like that.
Old Jun 30, 2019 | 06:45 AM
skinman13's Avatar
skinman13
Same here...plug 'n play on my 03 Ultra
Old Jun 30, 2019 | 07:39 AM
GalvTexGuy's Avatar
GalvTexGuy
You can't change just the bulbs. You replace the whole assembly.
Front - https://www.customdynamics.com/front...-touring?cat=2
Rear - https://www.customdynamics.com/wrap-...nder-tip?cat=2
Old Jul 1, 2019 | 06:45 AM
FLHTKCU's Avatar
FLHTKCU
Thanks
Now I just have to wait for time to do it, Looking at the instructions on line>>I have to remove the front fender. I didn't look ant the rear instructions It probably will be a winter project. That way, I'll have more time to fix a "mistakes".
mike
Old Jul 1, 2019 | 06:54 AM
Jmkelly's Avatar
Jmkelly
Originally Posted by FLHTKCU
Thanks
mike
I didn’t have to do anything other than pull the cover off and swap the bulbs out. Took longer to get the screwdriver out of the drawer than to do it all.
