Vibration when braking
Old Jul 10, 2019 | 06:37 AM
Jeff1759's Avatar
Jeff1759
Default Vibration when braking
2017 SSG. Lately notice when braking, and just a second or 2 before coming to the actual stop,I will hear and feel a strange vibration and unexplainable noise, kind of a fast paced chatter for lack of a better explanation, coming from front brakes.
Any idea what/why this might be?
Old Jul 10, 2019 | 06:50 AM
Notgrownup's Avatar
Notgrownup
Warped rotors maybe.
Old Jul 10, 2019 | 07:16 AM
blackxpress's Avatar
blackxpress
That would be my guess. I probably sound like a broken record by now but it’s time to replace your brake fluid if you haven’t done it already. While you’re at it, check the runout on your rotors and make sure the calipers aren’t sticking.
Old Jul 10, 2019 | 07:41 AM
grbrown's Avatar
grbrown
If you have ABS it is also possible that is kicking in, if you brake hard. I had a car that did it at every opportunity.
Old Jul 10, 2019 | 09:10 AM
Jeff1759's Avatar
Jeff1759
Thanks guys.
ABS yes, but not hard braking. Fluid level in reservoir sight glass always looks low to me compared to old bike, but could be the position it is in as mounted on the bars.
Planned on taking it in to dealer but time is hard to come by, figured I'd ask here first!
Old Jul 10, 2019 | 09:24 AM
lp's Avatar
lp
Originally Posted by Jeff1759
Thanks guys.
Like Notgrownup said, you have warped rotors. Very common issue.
Old Jul 10, 2019 | 09:27 AM
skinman13's Avatar
skinman13
in my (recent) experience, warped front rotors didn't make any noise, but would "pulse" when braking. Warping the disk can easily happen when inexperienced people replace tires and can be difficult to see. I warped the rear rotor on my Dyna and it didn't pulse, but the pedal felt soft and it would take multiple strokes to get braking.
Old Jul 24, 2019 | 06:04 AM
Jeff1759's Avatar
Jeff1759
Just got bike back from service. They said they found no unusual issues with brakes, rotors are fine, cleaned rear brake dust which was pretty bad. Guess I use the fronts harder than the rear, mostly to avoid listening to rear brake squeal. Time to do a better job of keeping rear brakes clean.
shaung
Sep 14, 2019 08:14 AM
Hoppy
2014-2024 Touring Models
Aug 26, 2015 08:01 AM
dgreen1069
May 1, 2015 06:32 AM
ronherman
Jan 23, 2014 08:59 AM
ctsbob
Aug 27, 2007 07:51 PM
