Limp mode
Old Jul 20, 2019 | 02:55 PM
Scotiagold's Avatar
Scotiagold
6th Gear
Default Limp mode
Hi. 2010 Roadking Classic. V02 breather, cats removed, and twin slashed rounds. Fuelpak installed. Recently my mileage went bad. 200kms a tank. Very sluggish as well. Went into limp mode and only way to resolve this is to eliminate Fuelpak. Took it to shop. He changed every modual except for ECM. Even verified sump pump. Changed fuel filter and tested pump. Runs but still sluggish with poor milage. Also won't hit rev limiter. He thinks it has to be ECM. Any one else had this issue? No engine work done ever. Thanks.
Old Jul 20, 2019 | 07:05 PM
soulpatch's Avatar
soulpatch
I'd say the same thing. Sounds like there is a fail in the ECM and it's gone into "safe" mode. Does he have one at the shop to at least swap out and test? Be the easiest way to know for sure.
Old Jul 20, 2019 | 07:40 PM
ORradtech's Avatar
ORradtech
Um, do I understand correctly that removing the add on fuelpak fixes it?
Seems to me it wouldn't be the ECM but the Fuelpak.
I admit to not being real familiar with the Fuelpak but basic troubleshooting techniques have you remove add on components and if the problem goes away the removed component is likely the problem.
Old Jul 20, 2019 | 07:50 PM
Screamin beagle's Avatar
Screamin beagle
If it were really in limp mode there would be codes you could retrieve rather than having your "mechanic" just throw every part in the catalog at it.
Old Jul 20, 2019 | 08:02 PM
soulpatch's Avatar
soulpatch
Missed that part about the fuel pack. Definitely check that first. Could easily be a defective one. Thanks for the catch ORradtech. I completely missed it.
Old Jul 21, 2019 | 06:43 AM
Scotiagold's Avatar
Scotiagold
6th Gear
Removing Fuelpak eliminates the check engine and limp mode but bike still lacks power and mileages is still cut in half. Also, bike won't hit rev limiter and only reaches 120kmh/75mph. Very sluggish to say the least.
Old Jul 21, 2019 | 06:48 AM
Scotiagold's Avatar
Scotiagold
6th Gear
I was told they are not swappable as they are programmed with VIN#.
Old Jul 21, 2019 | 06:50 AM
Scotiagold's Avatar
Scotiagold
6th Gear
I took the Fuelpak off before I brought it to him. I'm going to bring it to him so he can read code it give while it's on the bike.
Old Jul 21, 2019 | 06:52 AM
Scotiagold's Avatar
Scotiagold
6th Gear
No codes with Fuelpak removed.
Old Jul 21, 2019 | 07:13 AM
Geoff1200's Avatar
Geoff1200
Bad ECMs usually won't "tattle" on itself, only method I know of is to replace with a known good unit, rare, but it happens....
