Front spark plug issues
Old Jul 28, 2019 | 06:45 PM
Jojo79's Avatar
Jojo79
Stage II
Default Front spark plug issues
What’s up guys ! Hoping someone can help. Just put a new oil pump and chain tensioners on my 05 ultra classic but now I lost spark (or something) to the front piston. When I take the plug out and clean it the bike fires right but if I turn it off it won’t fire up again. Almost like it’s flooding out. The front plug comes out super black and the rear one is normal. Not sure what would cause this. Wanna say thanks ahead time for any suggestions
Old Jul 28, 2019 | 07:43 PM
xcbullet's Avatar
xcbullet
I would start with new plugs and wires
Old Jul 29, 2019 | 07:40 AM
Magnut1's Avatar
Magnut1
And look at the coil pack side when you remove the wires. Sometimes the coil nipples get corroded.
Old Jul 29, 2019 | 08:44 AM
vanman59's Avatar
vanman59
Check compression in both cylinders first and compare them with the specs, its easy and you were just in the cam chest. Or check for spark on the front cylinder first, then compression.
Old Jul 29, 2019 | 10:20 AM
skinman13's Avatar
skinman13
Start where you were sticking your dick pullers...probably either it is not firing or the intake valve is not closing ...
Old Jul 29, 2019 | 03:49 PM
Jojo79's Avatar
Jojo79
Stage II
Appreciate all the help definitely gonna start where I touched first and go do the line of suggestions
Old Jul 29, 2019 | 04:04 PM
50pannmore's Avatar
50pannmore
Not sure about the 05 but on my 15 the plug wires must be hooked up to the cylinder that they came from, Not like an evo or shovel where the coil fires both plugs everytime
Old Jul 29, 2019 | 06:31 PM
skinman13's Avatar
skinman13
same-same as 05
Old Jul 29, 2019 | 07:40 PM
470004's Avatar
470004
Welcome to the forum.
