So I bought a used HD OEM...LED Tour Pack Light,,, got it all bolted and wired before i left for my Sturgis trip...
The only running lights that illuminate is the center light on the back, the turn signals do not illuminate unless I hit the brakes.
It seems that the bikes i see have all of the lights lit up, and then get brighter for turn signal activation and braking... ...Question, can I run the running light power to the 2 turn signals to get them to illuminate, and then still have the turn signals work?
Sounds as if somethings not wired right. If I remember right, that picture you posted is the view from the pin end of the connector, not the end of the connector that the wires go into... that'll make a difference lol meaning, if you're looking at it from the back of the connector (the end where the wires go into the connector) its going to be the mirror image of that (E where D is and vice-versa, A where C is and vice versa).
What harness did you use? Did you have to make one up, having to install the connector on both ends.. or did you get one where you just added the connector to the light end and the end that plugs in under your seat already had the connector on it?
If you're adding the OEM LED King style H-D Tour-PakŽ (14-19 Models) to the 2015 FLHXS, you could use our Motorcycle Tour PakŽ Quick Disconnect Harness: https://www.customdynamics.com/quick...ur-pak?cat=878 Let us know if you have any questions!
Thanks, I will just order this to go with my Magic Strobe
I ordered and installed this before my Sturgis trip. Works as advertised
Plug arrived yesterday, it is all 6 pin and will not plug into the 5 pin as seen above on the schematic, I will return this
