Progressive tech no help
Old Aug 13, 2019 | 06:03 PM
My03flhti's Avatar
My03flhti
Setting the sag is simple measure from center of axle to fender then sit on the bike measure again should have 1 inch travel. Clearly the number of turns , adjustment will be different one or two up.
Ok. Thank you sir.
Old Aug 13, 2019 | 06:05 PM
My03flhti's Avatar
My03flhti
Originally Posted by 99Birdman
Rider sag (with the rider on board) should normally be set at 1/3 of total travel to allow for compression of the shock over bumps and extension of the shock when encountering dips. Sag one up will be different (sometimes significantly) than 2 up due to the passengers extra weight. Ideally you would change the setting whenever going from on to the other. If the proper spring rate is not installed to begin with, you won't be able to set the sag at all.
Sometimes, if you ask the tech to set you up for both, they will take both and then set the sag somewhere in the middle. This will make the ride rougher than needed when solo and softer when 2 up.
With suspension, you usually get what you pay for. There are quite a few good shock makers out there (check the suspension forum for ideas). Just make sure they offer a spring rate for your specific body weight and riding style versus off the shelf "standard/heavy duty".
Great reply. I’m leaning towards Ohlin. Thanks again
Old Aug 13, 2019 | 09:13 PM
moharley2000's Avatar
moharley2000
Call Howard at motorcyclemetal.com
Old Aug 13, 2019 | 09:24 PM
hdrider1's Avatar
hdrider1
Since you're going to junk the shocks anyway, why don't you back the preload way off and try it -- keep backing it off until it at the minimum or you bottom out on a bump and then add some. Was about the only way I could get at least an OK ride with the 944s on a Road King
Old Aug 14, 2019 | 08:19 AM
My03flhti's Avatar
My03flhti
Will do. Ty
Old Aug 14, 2019 | 08:20 AM
My03flhti's Avatar
My03flhti
I will try that. Can’t hurt right?
Old Aug 15, 2019 | 05:51 AM
y22c's Avatar
y22c
Originally Posted by My03flhti
I will. Now that presents a problem of what shock from what company. Who’s gonna sell me what in”really” need?
Before you buy anything, call Mike at Suspension Technologies and talk with him.
vanbarrq@lordsseed.com
Feb 22, 2017 09:34 AM
mainshaft
Nov 1, 2012 03:13 AM
billytha
General Topics/Tech Tips
Aug 31, 2012 10:04 PM
07JakeelwoodHD
Mar 26, 2012 11:45 AM
yotaweeler
Jul 20, 2010 01:25 PM
