Stripped Upper Engine Mount Bracket
Old Aug 28, 2019 | 09:42 PM
sanman4ever's Avatar
sanman4ever
Exclamation Stripped Upper Engine Mount Bracket
Having issues with replacing the upper engine mount bracket. I could tell when I was taking it out it was having issues. Dam screw is all stripped and cross threaded. No way it's doing back in correctly Looking for a solution.
Old Aug 28, 2019 | 09:50 PM
hardheaded's Avatar
hardheaded
Pull it out and oil it up and chase the threads before installing a new bolt. You could always install a Time Sert too.
Old Aug 28, 2019 | 10:02 PM
sanman4ever
Not familiar with a Time Sert?
Old Aug 28, 2019 | 10:25 PM
TwiZted Biker's Avatar
TwiZted Biker
Run a tap all the way through the mount hole from the front side it should be full threaded and just use a longer full threaded bolt to get to the new intact threads.
Dicking with a helicoil or time sert there I doubt you have the working clearance to get the drill in straight without shifting the motor. Mine if the longer bolt didn't bite enough I'd just drill the damn thing oversize all the way through, long bolt with a locknut on back side.
Old Aug 29, 2019 | 09:07 AM
sanman4ever
Running the tap worked perfectly. There was also a lot of noise in the hole. Looks like some old lock tight and some rust. But the tap cleaned it all up. It's all snugged up to spec now.
buboje
Jun 12, 2017 01:12 PM
cujo471
Apr 14, 2013 08:29 PM
hog95023
Oct 10, 2011 06:11 AM
SA315B
Aug 28, 2009 07:59 AM
cruise_carter
Aug 28, 2008 06:40 PM
