EITMS disabled. Will it hurt the engine ?
Old Sep 14, 2019 | 08:45 AM
smitty901's Avatar
smitty901
Newer bikes you can turn it off and on as you wish in seconds. having it on hurts nothing. Some as you raise the rpms a bit it shuts off anyway. Lot of fuss over nothing. It is meant for the rider not the bike anyway.
If you wish to reduce the flt heat on rider and passenger get rid of the CAT. The heat , that comes off them is a big part of the problem . That is how they work by getting real hot. Removing it has No effect on your engine.
Pisses EPA off a bit.
Old Sep 14, 2019 | 09:02 AM
Sam2010's Avatar
Sam2010
Originally Posted by 99Birdman
Personally not a fan of HD's implementation but, it's there for a reason (they do not add build cost unless there is a return in warranty claims).
Put some money into good heat management (tune, fans, good oil cooler) and it won't kick on.
Not true on 14+ Ambient Air Temperature Control.
Old Sep 14, 2019 | 09:08 AM
Tired's Avatar
Tired
I used my PV to kill it 8 years ago. I've never missed it once.
Old Sep 14, 2019 | 10:42 AM
PoCoBob's Avatar
PoCoBob
Mines off most of the time but I will turn it on if I get caught in heavy traffic on a hot day. I have a powervision and I've talked to both Fuelmoto and Dynojet asking if there's a way to change that 80 degree threshold to 90 or 95 degrees. They both said no, you can adjust the engine temp settings but not the ambient temp setting. So I just turn it off.
Old Sep 17, 2019 | 09:57 PM
99Birdman's Avatar
99Birdman
Originally Posted by lp
Fairing bikes it's 80 degrees ambient. Bikes without fairings it's 288 degrees engine temp. All of this is in your owners manual.
Originally Posted by hardheaded
Yea, the new bikes kick the system on at anything over 80*. I turned mine off when i bought the bike and haven't had it back on since.
Thanks for the education, gentlemen.
Since I don't have one of the AATC affected bikes, I did not know that.
All the more reason to implement a good heat managment system and turn that sucker off, I would think.
Old Sep 17, 2019 | 11:01 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
No, it will not hurt the engine to turn EITMS off. EITMS is only a rider comfort feature.
Old Sep 18, 2019 | 09:17 AM
xlbuilder's Avatar
xlbuilder
Physics says that it will require the same amount of energy to spin the crank at the same idle speed whether you fire one or two cylinders. Unless you open the valves on the dead cylinder to eliminate the pumping losses, the front cylinder works harder when the back one shuts off. The BTUs are the same. It just moves the heat away from our inner right thigh. I run mine off all of the time and never consider turning it on. Besides, I like the Harley idle sound more than a big single idling.
Old Sep 18, 2019 | 09:34 AM
harkon's Avatar
harkon
When it turned on, I almost always got a ping when I used the throttle to get going again. That ping really bothered me. I added a PV, header, mufflers, intake and a Jagg oil cooler /w fan. It's been a very long time since it's come on. As mine is a 2012 engine temp was the main factor in it turning on, I think. It's still enabled, but it hasn't activated in the past 2 summers at all, since I added the oil cooler. The oil cooler fan runs a lot, but EITMS never does anymore.
Old Sep 18, 2019 | 02:33 PM
kupitz's Avatar
kupitz
My dealer specifically advised they disabled it for me.
Old Sep 19, 2019 | 05:40 PM
slapshot12's Avatar
slapshot12
I turned mine off shortly after I bought the bike. I tried it for a few months and didn’t like it. It hasn’t been turned back on since and I’ve had no issues here in steamy Florida.
