I want more torque in the 2000=3500 range. 2016 Streetglide with high flow air cleaner, Vance and Hines true duals, and Vance and Hines Fuelpack tuner. Any suggestions on what cam to use and will I need to upgrade the pushrods and get a better race tuner?
I believe you can use the stock pushrods on either of these cams. If you have the FP3, Vance & Hines can provide you with a tune that will work for your setup.
My Dyno guy talked to me about a cam uograde. He was pushing the S&S MR103 cams. He said he would do it for 1200 OTD with a Dyno tune. I currently have a AC and full exhaust I ride mostly 2500-4000k.
X2. I'm running the 48H's myself with stock pushrods. After dyno tune with SEPST I've got over 100 tq from 1500-4000 rpm.
I'd recommend taking the opportunity to upgrade lifters while you're at it.
Yes, they are Dresser Duals. I don't like the looks of the 2 into 1 pipes. What exhaust would improve torque?
Those are the absolute worst of the true dual set ups for robbing you of performance. I felt the same way about a 2/1 looks wise at first but now I they look cool. More of like a hot rod. Most companies make a "ghost" pipe for their 2/1 pipes
You don't have to use a 2:1 system to get good torque. I have an S&S header that has a hidden crossover, making it a 2:1:2 system. There are many other brands that offer the same configuration.
