Another vote for the SE 254e cams. They are basically the same as 255s, but don't need ACRs & won't eat your starter motor. I got 'em in my RKC, when I let out the clutch in 1st gear, the revs don't drop down; the bike just jumps off the line.
Twincaman,
I had the Woods TW-222 cam installed on my 2016 ultra, I also used the screaming eagle 110 big bore kit with CVO heads and a D&D 2 into 1.
Getting 99.6 hp and 110 ft. lbs. of torque. SAE corrected.
I am hitting .100 ft lbs of torque at 2200 rpms and stays thru 5000 rpms.
it is a a kick in the pant torque combination.
I have read that Fulsac makes a headpipe combination that has real good low to mid range torque
