Trailer Ramp Help
Old Oct 2, 2019 | 07:44 PM
TXNT's Avatar
TXNT
Drive the rear wheels of the truck up on 2x6's, this will lift the rear of the truck thus lowering back of trailer, 2 boards should be enough to help you.
Old Oct 2, 2019 | 07:47 PM
Foxcroft007's Avatar
Foxcroft007
5th Gear
Sounds like a simple enough solution. Much easier than dragging my huge ramp across the country.
Old Oct 2, 2019 | 09:51 PM
TXNT's Avatar
TXNT
Lets us know how that works for you. Good luck!
Old Oct 2, 2019 | 10:00 PM
dickey's Avatar
dickey
I just use a hitch that has a slightly raised tongue & ball,then the front of the trailer is up slightly, thereby lessening the break angle of the ramp & trailer bed.
Old Oct 3, 2019 | 07:38 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I've also used the likes of a 2x4 under the ramp where it hit the pavement. Cheap, light and effective.
Old Oct 3, 2019 | 10:03 AM
hattitude's Avatar
hattitude
Originally Posted by Foxcroft007
I have a utility trailer with a 4’ metal ramp. I use a biker bar to secure the bike while towing but the issue is that the ramp is quite steep and I tend to hit my frame when transitioning from the trailer to the ramp.
Has anyone built a hinged extension for their ramp? Any other ideas or options?
Just carry a couple good jack stands......
I use a utility trailer for the rare times I tow one of my bikes. It's a 5x10 with a short, metal mesh ramp. I put a jack stand (or two) under the rear of the trailer, to catch at the frame. I then disconnect the trailer from the tow vehicle and jack up the front of the trailer, until the rear frame is solidly resting on the jack stands. I can then easily load or unload the bike, with a much reduced ramp angle...
The keys are to make sure the trailer is loaded with at least a slight weight bias to the front of the trailer, and that the trailer jack can handle the weight.
RSDUDA
May 31, 2020 12:21 PM
Hard Ride
Mar 17, 2016 07:24 PM
Singletrak
Dec 5, 2010 04:40 PM
Mike67
Oct 30, 2010 06:53 PM
turbo54
Jan 14, 2007 08:27 PM
