TC 96 initial impressions
Old Jul 15, 2007 | 12:19 PM
Greb's Avatar
Greb
Default TC 96 initial impressions
My father rented an 07 Electra Glide Classic so I jumped off my 06 Street Glide and traded up to see what I thought. First thing I noticed was the torque difference, although it was not stock and my TC 88 is. It had a stage one air cleaner, Screamin Eagle pipes and a remap so I can't speak of stock vs stock, but in the power department it left me kind of sad when I got back on the 88. The fifth gear whine everyone seems to be dissapointed with was unfounded by me. It is alot like the fourth gear whine on my 88 so it was nothing new for me to hear it. Cruising along with the six speed was awesome, although it only drops the rpm a couple hundred it felt great and now I want the 6 speed. I could feel a significant heat increase radiating from the 96, so that is something that I would not like. It just ran hot, so when I got back on my 88 it felt so much better. We compared gas mileage and suprisingly they were both running 43 MPG. I thought that was great to see that you can have more power with no gas mileage penalty. I guess the only draw back I could see is the heat issue. A great ride and I wish I had waited another year to buy a new bike.
Old Jul 15, 2007 | 12:28 PM
Bigredone's Avatar
Bigredone
Default RE: TC 96 initial impressions
Did you forget about the $$$$?
Old Jul 15, 2007 | 12:33 PM
dirtdobber's Avatar
dirtdobber
I have rode the tc 88 and now I have the 96 w/6 speed. I prefer the 96ci. Yes it does run hotter but it can be taken care up to a point. The new oil cooler that is offered by Hd helps some. Most of heat that I notice the most is the split header pipe. I am changing very soon to true duals. I rode a friends that has the V&H trues and touring mufflers with screaming eagle breather. It was much stroner and a lot cooler than mine. The torque should be more it does have 96ci. I have realized- with me anyway-when I get a new bike I always say I should have waited till the next year. Changes always makes one think, why did I not wait.
Old Jul 15, 2007 | 12:59 PM
debay's Avatar
debay
You just need a stage 1 for the 88
Old Jul 15, 2007 | 01:05 PM
lschultz's Avatar
lschultz
Son got his 07 Roadglide few months ago and after riding it some that light bulb came on in by head and I went and bought me a 07. At this monent it is still stock but that will change shortly. He put Rinehart TD, K&N 3908 filter, Dobeck TFI on his and she goes now. I had Rinehart slipons that I took off the 06 that will go back on this one.
Old Jul 15, 2007 | 01:43 PM
iclick's Avatar
iclick
ORIGINAL: Greb
That's what I noticed immediately when I rode an '07 demo bike (RK) last August. I was very impressed by the power on this stone-stock bike with 50 miles on the clock, and the engine was smoother than my Evo or any TC88/95 I had ridden in the past. That experience didn't leave my memory, and three months later I bought an '07 SG. Still impressed with this engine!
Mine whines, but not enough to matter. Installing 85w140 gear oil helped considerably, and all but eliminated the clatter in 5th and 6th.
After months of tweaking the PCIII I have mine up to about 50 mpg, which is acceptable, but below that of my Evo, which could get 55mpg without trying.
The heat issue diminishes greatly when you get control of your A/F ratios, via engine-management mods (SERT, PCIII, T'Max, etc.). The '07's run very lean in closed-loop mode (idle and cruise when at operating temperature).
Old Jul 16, 2007 | 09:53 AM
nidan's Avatar
nidan
I've owned 2 stock /stage I TC88's, , a 108hp 95" , and the stock 96 "and now 103 stage II Street Glide. The Stock TC96 is not a lot different than the stage I TC 88's but the 6 speed makes it more flexible. Even though my 103 doesn't make quite the power of my 95 it is much more user friendly .. and there is plenty of room to grow
Old Jul 16, 2007 | 10:21 AM
Greb's Avatar
Greb
I eventually want to put the big bore 95 kit on my bike. But what kit? If Edelbrock's kit is what it promises to be that would be the direction I would go. I hope everyone that has problemswith their 96 gets them resolved, I think that perhaps like some have stated earlier, Harley might not have done enough R & D before they released it to the masses.
Old Jul 16, 2007 | 10:33 AM
daconiam's Avatar
daconiam
I would rather have more low end "drivable" torque than the 96"has right now. The peak tourque should be around 2500rpm vice 3500rpm.
Old Jul 16, 2007 | 11:57 AM
woodreaux's Avatar
woodreaux
Wish my o6 EGC had it but it's got a 95 with headwork and
a 6 speed no whine tranny.
My 07 Dyna has the TC96 and I think the engine is great platform.
It has lots of room to grow. HD did good with this one.
