Possible? Yes.
Reliable? Sure- as long as you make the right choice, and it isn't going to be cheap ( "Fast, Cheap, Reliable- pick two" )
Practical? Maybe not so much. 120 HP in a 98" motor will be a right side build. Picture a formula 1 engine in a semi
Can get, or use effectively? I was able to get 150+ out of a 95" motor with a pro charger. Wasn't much good to me because it was a 1100 pound bagger, and it didn't break 100 TQ until after 3000 RPM.
More than one horse power per cubic inch starts getting quite expensive. Even if the motor were bullet proof, what ELSE are you planning on modifying? Parts engineered for about 87 horse power will only last for so long with an almost 50% increase in power output. This leads to a long, irritating "research project" into what the next weakest part will be.
I’ve got a 98” with 117 hp/ 113 ft lbs. Woods 8 gear drive cams, heads by Wes Brown. It’s great in a Dyna, but I don’t think I would put it in a bagger. Runs out to the limiter (6600) still at 116 hp. Wouldn’t be horrible with a touring exhaust I’d guess. (Low end torque wise). Static compression is 10.89.
Yes, you can get 120 HP from a 98" semi-reliably IMO. I wouldn't push that far though. It's 1.22 HP per CI. Anything over 1.2 is gonna cost you- money and some reliability.
I had an all bore 107" that pulled 120 HP and 131 TQ from an undersized TB (50mm). My dyno tuner who tuned me a couple diff cams over the years said I could've pulled 130 HP (1.21 HP per CI) with an HPI 58mm but said there was no point. Especially on a touring build. My CCP was 205 which was enough as well for a touring build.
IMO...... aim for about 1.1 to 1.15 HP per CI (108-112) at most. Unless you just wanna hit 120.... which just costs money. And......reliability.
