2013 road glide limp mode
Old Oct 11, 2019 | 12:17 PM
Rodney Graham's Avatar
Rodney Graham
Default 2013 road glide limp mode
have a 2013 road glide with a 103 it's been going into limb mode( no throttle will hold 1500 rpms hard to start) After it cools works ok. I get three codes P1511 EFI Power Management Mode, P2100 EFI Motor Circuit Open, P0031 Front HO2S low/open is it a ECM problem or EFI motor bad. any info would be helpful
Old Oct 12, 2019 | 06:12 AM
Hammerhead Pat's Avatar
Hammerhead Pat
Pull apart the connection behind your air cleaner. Blow it out and apply some dielectric grease or spray and push back together firmly. Very common issue ….
Old Oct 12, 2019 | 08:05 AM
memphisharley's Avatar
memphisharley
I agree with Pat. however, does anyone know a "fix" for this reoccurring issue as I'd like to put it to bed.
Old Oct 12, 2019 | 09:40 PM
Rodney Graham
did all that still does it turn power on and you can hear a load clunk come from it like its resetting run for 2 minutes fine then back into limp mode next I put my hand on the motor and can feel the clunk and it gets hot quick. ordered a new throttle body assembly we will see in a couple of days.
24seven
Jul 18, 2017 06:17 PM
RET_SCPO
Milwaukee Eight (M8)
23
Jul 16, 2017 11:00 AM
omaho5
May 16, 2013 11:25 AM
mduggan
Jul 13, 2011 11:40 AM
iraqiebeachbum
Aug 20, 2010 04:08 AM
